Home > Help Needed / General Tech Chat > gearbox ratio ???
minisurf
Member #: 1595
Hello,
I've got an MG metro turbo engine and I want to know what is the standard diff ratio on the gearbox. There is nothing on the gearbox so I don't know what it is
I'v got a 2.95 diff ratio on my mini but I'm look for a 3.44 to fit my turbo engine so it will be great that the standard gearbox could be one
But unfortunately I suppose that's a 3.2
Thanks for your help
If it really is a genuine non messed with tubo gearbox then it will have a 3.2:1 diff ratio.
minisurf
Member #: 1595
normally it's a genuine engine.
My trouble is that it's a goldseal engine with a strange number.
For example the piston's ref is 20831 wich seems to be +20 pistons.
Si my gearbox is normally a 3.2:1
Thanks a lot
What's the ratio for a N/A metro? Is there a list of g/box number = ratio, or doesn't it work like that?
turbo hogster
Member #: 178
stowmaket suffolk
it could be any thing most were 3.4 but my mg had a 3.1 in it from new so take your pick
minisurf
Member #: 1595
The only ref I found is on the diff : 83/12 in a circle
and the ref of the engine : BHM1668E 147716
minisurf
Member #: 1595
I spend my time searching everything about this engine but I always find contradictory informations
So once and for all
ref of the pistons : 20831 ID19 (standard size or +20 ?, dish ??)
diff ratio : 83/12 ??? impossible
That diff ratio is definately wrong.
That's a 6,91:1 ratio which is nonsence.
The numbers you should be looking at for a 3,44 is 62/18
danboy
Member #: 1381
Date code Dec 1983 or possibly week 12 in 1983
Regards
Dave
So once and for all
To be quite honest looking at the reference numbers on BL engines is a waste of time and bloody effort as they are not a reliable indicator of what you have, especially with an engine that is potentially 20-25years old now and may have had any amount of buggering about done to it.
If you want to know what you have I suggest you get the measuring sticks out and measure pistons, and count teeth on the crownwheel and the pinion.
minisurf
Member #: 1595
I just count the teeths : 63/19 so My gearbox is 3.21 ratio...sniff
Now I have to resolve the pistons number
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=711
minisurf
Member #: 1595
thanks
so my pistons have a 12cc dish
icklemini
Member #: 745
Northampton
"My gearbox is 3.21 ratio...sniff "
I have a 3.44 if you fancy doing a swop??
