| Home > Help Needed / General Tech Chat > Guess the turbo again | |||||||
29th Mar, 2007 at 08:48:54pm
picked up my new turbo last night and wondered if anyone could identify it? The chap said its a T25, brand new from garret but i've no idea what car for (he got it off a mate who worked in the industry).
29th Mar, 2007 at 09:19:21pm
Interesting - the drain looks like a T25, but I've never heard of a T25 with a 0.35 turbine?
29th Mar, 2007 at 09:33:13pm
core reminds me of the mondeo/escort 1.8TD turbo got one lying around somewhere will check the numbers :) turbo 16v k-series 11.9@118.9 :)
29th Mar, 2007 at 09:36:19pm
ford 1.8TD is a .48 / .30 with thedowpipe cast into the exhaust housing, but similar none the less :) may be worth looking at a bigger ford TD for ispiration? turbo 16v k-series 11.9@118.9 :)
29th Mar, 2007 at 09:51:07pm
29th Mar, 2007 at 11:08:35pm
Not a monestro turbo unit .... I have one of those and that's not it. For interest IIRC the Monestro TD unit is 466770 for a serial number .... I posted a thread on here a while back to see if anybody had the map. Every day is a school day ...........
29th Mar, 2007 at 11:32:49pm
cheers dudes, i'll have a sniff round the net and see what i can dig up.
30th Mar, 2007 at 02:31:21am
Take off the compressor, measure the OD, and diameter of the inducer, and that'll tell you pretty much all you need to know. On 17th Nov, 2014 Tom Fenton said:
30th Mar, 2007 at 07:01:13am
They're the same A/Rs as an R5 GT T2, so seems like a reasonable punt.
30th Mar, 2007 at 11:25:03am
the montego TD one doesnt have the T25 style 2 bolt oil drain, it has the large pipe with a conical seat and nut type thingy. |
30th Mar, 2007 at 12:29:44pm
this isn't a 2 bolt oil drain, its the same as keans turbo, which we think is a T25 aswell. sounds like what you're describing iain?
1st Apr, 2007 at 07:19:35pm
took off the comp housing today to measure and rotate it aswell. the inducers 50mm wide at the base and tapers to 40mm at the end, roughly measured with a tape measure cos we couldn't find the verniers. Does that make it any good? and how do i figure out the trim of it from that? On 20th Oct, 2015 Tom Fenton said:
1st Apr, 2007 at 07:56:43pm
Ah, well - it LOOKED like a two-bolt drain LOL!
20th Apr, 2007 at 12:49:30am
had a proper measure tonight and its a 55 trim, does that give you anythng more to go on? On 20th Oct, 2015 Tom Fenton said:
20th Apr, 2007 at 01:40:30pm
nope. Unless you tell us what the wheel diameter is. On 17th Nov, 2014 Tom Fenton said:
20th Apr, 2007 at 02:42:00pm
d'oh. kean if you're readin this dude can you jot down the sizes we wrote in your garage :) On 20th Oct, 2015 Tom Fenton said:
20th Apr, 2007 at 10:46:37pm
right it's 51.43mm at the bottom and 38.11mm at the top (not sure on the correct terms)
4th Jun, 2007 at 06:02:48pm
ok, I was wrong. I've found several refernces to a 51.4mm diameter wheel.
4th Jun, 2007 at 10:16:13pm
aaah right, so i'll have a bash at finding a metric banjo around the same as a 7/16...any idea's on a rough guess? i know wil mentioned m12x1.25. On 20th Oct, 2015 Tom Fenton said:
4th Jun, 2007 at 10:37:22pm
I'd start with the one Wil suggested. Banjo bolts for these should be easy to find - I think it's the 'metric' standard brake fitting size.
4th Jun, 2007 at 11:29:14pm
http://www.not2fast.com/turbo/maps/t25_55_saab.gif
5th Jun, 2007 at 05:14:17am
I also found some gt wheels in t25 configuration (clamped comp hsg),
5th Jun, 2007 at 09:16:38am
yeah i'll measure it when it comes off to sort out the oil feed banjo :)
5th Jun, 2007 at 01:51:20pm
As Fab says - the 0,35 turbine is unusual on a T25, although I did find a few references to the wheel and compressor AR used on a JohnDeere, so maybe here is a part we know nothing about.
5th Jun, 2007 at 01:53:47pm
all i can find on the turbo is:
me said:
the numbers i can find on it are: inlet: A/R .48 exhaust: A/R .35 other numers on the exhaust side are, M-26 and PT-1. there's no plate with a serial on or anything. Its not water cooled either, just oil. the elbow is a 5 bolt one. On 20th Oct, 2015 Tom Fenton said:
