Home > Help Needed / General Tech Chat > Megajolt wiring
Tikkel
Member #: 642
Hi.
anyone who has any links of wiring diagrams for how to wire EDIS and megajolt 3.0 in my mini. Cant seem to find it anywere.
anyone can by four letters, but legends arent for sale!
Is this any help:
http://www.autosportlabs.net/MJLJ_V3_vehic...tallation_guide
colas
Member #: 102
Pennsylvania USA
Also do a search on here for "megajolt" there is a thread by nic that explains how to do it all.
I came across this wiring diagram on Autosportlab's website a while back:
Unfortunately I can no longer find it on their site.
Tikkel
Member #: 642
And we have a winner.... its alive!!!!! Thanks guys!
Skinns46
Member #: 165
Cambridge
First off...Sorry to bring up an old thread.
Does the power to the coil pack need to come off the ignition switch?? or is any old 12v Feed. I've got 2 diagrams both with different ideas.
Roland
http://photobucket.com/albums/y139/Skinns46/
I used the original coil feed, but my car was old enough that I didn't have a ballasted system.
Failing that run a wire down from the fuse box.
Skinns46
Member #: 165
Cambridge
Ahhh so any old 12v thats live when the ignition is on will do then.cool
Cheers mate
Edited by Skinns46 on 11th Jun, 2007.
No problem *wink*
yep, though i discovered that i was running a permenent 12v supply to my coil pack for just over a year.....
oops
QuimFintas
Member #: 1021
Portugal
5th of September, 2007 at 09:57:49pmPM User | Quote | Manage Attachments | Edit
Hi, tomorow I go install my megajolt, I have one question.
Need I use a fuse in positive wire that go to edis coil and module?
To megajolt I use a 2 amp fuse, that is correct?
Daniel
You should always use a fuse in any live supply. If the wire became damaged and shorted to earth, without a fuse you have a fire.
YES! what Tom says!
its not funny when it goes wrong.
My mums ex bloke (who was a complete tool!) put a stereo in her car, he flashed somthing and blew the fuse putting it in so he soldered a bit of wire across the fuse.....
anyway, she had some problem with the car so i took it round the block, went round a corner and somthing obviously shorted where he'd make a hash of wiring it with sellotape, smoke pours from behind the dash, I pull over ank kill the ignition, smoke carries on because he's wired it straight to the battery.... luckly the stereo wasn't pushed all the way in so i pulled it pronto and ripped the red hot wires out with my bare hands before the whole car went up.
with out a fuse it'll only take a couple of seconds for wiring to reach red hot if you get a short.
QuimFintas
Member #: 1021
Portugal
I "fuse" evreything, but I need to know witch fuse I use to Edis module and spark coil?
To megajolt I use 2 amp, is it correct?
Daniel
QuimFintas
Member #: 1021
Portugal
I will use 15A fuse like this image show.
Another question, is necessary use the 25uF capacitor?
Daniel
