| Home > Help Needed / General Tech Chat > steering at 150 bhp problem | |||||||
8th Apr, 2007 at 06:55:07pm
the car has a problem !!
8th Apr, 2007 at 07:00:00pm
8th Apr, 2007 at 07:05:33pm
blimey that was quick gavin ,thanks , um yes back is about 3/4 inch higher , rack seems fine ill have a really good go at the rack tomorowcastor angle i dont know ill find that out on wed , it is even both sides and id guess i set it at standard so 3.5 .weird thing is its not a power on /off situation , its a steady power on ! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
8th Apr, 2007 at 07:05:52pm
Tracking @ 1/16" is this a four wheel alignment figure or have you just set the track on the rear wheels? On 5th Sep, 2011 Vegard said:
8th Apr, 2007 at 07:14:45pm
My guess would either be that perhaps you have some wear somewhere? Radius arm maybe?
8th Apr, 2007 at 08:04:33pm
Tracking again robert check this out
8th Apr, 2007 at 08:08:35pm
On 8th of Apr, 2007 at 07:05pm Scruffy said:
Tracking @ 1/16" is this a four wheel alignment figure or have you just set the track on the rear wheels? thanks scruffy um i remember setting the car up with the viz book nos , so i think that was 1/16 in at back and 1/16 toe out at front , or may have been 1/8th ill check . i know i set it with two strings down the side of the car and got it all square and it has really phenominal handling.well normally !!!
8th Apr, 2007 at 08:12:50pm
On 8th of Apr, 2007 at 07:14pm Tom Fenton said:
My guess would either be that perhaps you have some wear somewhere? Radius arm maybe? Or it could be an impending problem with the diff planet wheels perhaps? The single pin diffs do the job for a time, it is just the potential damage to the rest of the engine from swarf when they self destruct that I don't like! thanks tom , ill check the radius arms , but i think they are fine , the diff has done about 3 k miles from new hardened pin new palnets new thrusts and diff bearings and bushes all through ,basically all i could do at the time to make it last ..lol fat chance i know . i was just looking into the 4 pin and seeing if i could change it with the engine in apparently i can ... Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
8th Apr, 2007 at 08:17:26pm
also stiffen the shocks up at the rear this will help somewhat as the car rear will not then squat down and lose the front steering so much increase caster to 5.5 deg this will help a great deal after you check out all the other obvious things thanks steve yes ill check this again on tues ,i will also try raising the back when i can to 30mm over front to see if that helps , it ws reading something on here about the 4 pin helping steering that made me wonder about the single pin causing the torque to flip from side to side , it all handle v v well at 122 bhp!! oh i should have said , its got poly bushe front tie rod bushes , rose jointed bottom arms ,and sub frame bolted to floot pan along the back too tyre pressures are 28 front and 25 back im not runnig the metro flanges so offset is minimum consistant with 6 by 12 revos ,whatever their offset is i dont know . Edited by robert on 8th Apr, 2007. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
8th Apr, 2007 at 11:48:20pm
I've had similar problems in the past when I had a front shock start to degrade. Might be worth pulling them off and checking to see if they feel similar and that there is no sign of leaks etc.
9th Apr, 2007 at 03:22:06am
im going with the castor too, im running 5.5 or 6 deg too |
9th Apr, 2007 at 10:03:31am
thanks roger and nic , ill check my caster on tues ,and if its low ill adjust it up , also ill chech the dampers thers deff no oil from them but whats going on inside who knows ,the symptoms only really come about when doing high speed and then trying to steer a little bit ,eg putting on power and then turning the wheel to overtake , a v small steering input becomes a dash to the oposite verge ,and then when one corrects it realizes an affinity for the car one is overtaking!! if i accelerate hard with no other car in the way ,and just hold it straight ,its fine , it only happens when i try to change direction , it reminds me of when i had 2 gearboxes in the tvr and could change to 4th whilst being in reverse , every input was massively exagerated ,but thats another story ,i degress .lol Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
9th Apr, 2007 at 10:57:02am
Robert, I think it would be well worth giving the back end a thorough check.
9th Apr, 2007 at 11:11:16am
thanks dave ,
9th Apr, 2007 at 11:13:47am
You last sentence would suggest the diff is locking up under the increased torque. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
9th Apr, 2007 at 11:20:14am
thats what i suspect axel ,thinking maybe a 4 pin would stop this ,ill check all the other stuff first though ..
9th Apr, 2007 at 11:47:35am
Yes, I agree, having had a standard diff fail on me in the past (planet wheels lost teeth and locked up) it does make the car drag itself about all over the road. Fingers crossed its something else though, when I first got my 205 the rear beam was sh@gged with lots of play in the radius arms, this had a similar effect to the one you describe in that when driving it hard, applications of power would cause the car to steer on its own from the rear, countering with steering made it worse LOL. Obviously its far easier to check out the radius arms and rear wheel bearings etc before stripping the engine to get at the diff, also if you have adjustable rear brackets have these moved perhaps?
15 Posts Member #: 231 Member |
10th Apr, 2007 at 12:30:19pm
my mini does this and ive never been able to find out how to stop it. the only thing ive noticed is that if the tyre pressures on the front axle are slightly different then it make it alot worse or if the tyres are too hard. ive been runing 15-18 psi in mine. this has made it quite a bit better! |
10th Apr, 2007 at 04:48:31pm
Pointing more towards low castor with every post! Every day is a school day ...........
10th Apr, 2007 at 07:49:45pm
Mine had a similar problems, except mine did it at all speeds..it kept wandering all over the place.
10th Apr, 2007 at 08:31:06pm
On 9th of Apr, 2007 at 11:47am Tom Fenton said:
Yes, I agree, having had a standard diff fail on me in the past (planet wheels lost teeth and locked up) it does make the car drag itself about all over the road. Fingers crossed its something else though, when I first got my 205 the rear beam was sh@gged with lots of play in the radius arms, this had a similar effect to the one you describe in that when driving it hard, applications of power would cause the car to steer on its own from the rear, countering with steering made it worse LOL. Obviously its far easier to check out the radius arms and rear wheel bearings etc before stripping the engine to get at the diff, also if you have adjustable rear brackets have these moved perhaps? Another one is to dump the oil and go fishing in the bottom of the gearbox with one of those extendable magnets on a stick to see if theres any debris in there. thanks tom , was felling a 40ft tree in the middle of oxford today so didnt get to the car ..ill deff check the back end tomorrow , and all ther other checks mentioned ,,the thing i find interesting is that it handles brilliantly at 120 bhp ,i think that a 4 pin is a given at this power ,and im only at 9.5 psi so its going to get more of a liability as boost goes up . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
10th Apr, 2007 at 08:34:02pm
On 10th of Apr, 2007 at 12:30pm Browncowracing said:
my mini does this and ive never been able to find out how to stop it. the only thing ive noticed is that if the tyre pressures on the front axle are slightly different then it make it alot worse or if the tyres are too hard. ive been runing 15-18 psi in mine. this has made it quite a bit better! well if i fix it ill deff let you know !!lol im running 28 on the front ,and iknow they were the same pressure ,so i can rule that out ,thinknig bout it a lower pressure would make the tyre drag more so maybe the castor angle would have more effect ,so maybe that what you need bcr a bit more castor like steve and nic run , i think i will try 5.5 degrees anyway . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
10th Apr, 2007 at 11:06:40pm
5.5 to 6 deg castor is the way forward.... literaly Every day is a school day ...........
17th Apr, 2007 at 08:57:28pm
WELL I HANG MY HEAD in shame :( Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
18th Apr, 2007 at 12:06:29am
be paitend rob and persistant that way you will get results
