Home > General Chat > straight cut gear sets
martpaul
Member #: 668
newton aycliffe (near durham)
Hi
just on the minispares website,
and im wondering what the difference is between the clubman and evolution straight cut gear sets is?
are the evolution an ok set up? just i can get some cheap! or am i better off with the clubman?
thanks martin
martpaul
Member #: 668
sorry after looking they seem to be the same set!
i always thought they were two different sets!
sorry
I think one set you use your own 1st gear, the other set comes with a 1st gear.
JT
Member #: 637
Hertfordshire
think there the same, well evolution make the clubman set at least!
My build thread..
yes i use the clubman set and i have to use the standard 1st gear, this is what make it a bit cheaper *wink*
The ST set has got a different ratio. This makes the first gear different. The reverese idler must also be changed. The Clubbie kit retains the standard first gear and reverse gear.
However, the ST kit has got three laygear bearings. I think this is a VERY good idea, although MiniWilliams proves that the Clubman set is rather good as well.
Edited by Vegard on 16th Apr, 2007.
Vegard, is the 3 bearing kit you are saying about the "Pre" A+ gear kit?
As i used the gear kit a few times with 3 bearings, it had 2 smaller bearings one end and the normal size the other.
I had no more or less wear by swapping over to the 2 bearing type, if thats a help to any one.
your right it was / is a good idea using 2 bearing one end, but if its the one i used, as the bearings were smaller it was seen that a single larger bearing would be better as it spins slower from being bigger.
the clubman set seems to cut the mustard, up to power figures around 200 bhp
*wink*
JT
Member #: 637
Hertfordshire
iv got the ST set which i think jacknight do?
i only got this as it was a bargin price on ebay! brand new aswell!
i think the ratios are only very slightly differnt to the clubman set.
My build thread..
Wouldn't the larger bearing spin faster? It does have more load area though.
