Home > Help Needed / General Tech Chat > N/a distributer in turbo engine temperarily
I want to get my turbo engine running in the garage to check it's a runner/not broken, the turbo distributer it has is the early type with the strange module that plugs into a connector block. I don't have the module, so I have shoved an n/a electronic distributor in and now gained a healthy spark on crank over. By rotating the body of the distributor slightly left will I avoid detonation due to the differing advance curves.
I must stress it will go in the car when rebuilt with either a turbo distributor or mega jolt.
Thanks.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Should be ok to check so long as there is no load and you set it "safe" advance wise.
Nick
Member #: 154
Midlands
it'll be fine dude
just one quickee. when I said it had gained a healthy spark, that was last summer and I pulled everything electronic like off to clean the engine.
Where do the red and black wire connect to from the ignition module on the side of the distrubor?
I have conected the red wire to the positve connection of the coil, is the black an earth or does that go to the negative connection?
Thanks.
Edited by minimole23 on 24th Apr, 2007.
To the neg connection on the coil.
