| Home > General Chat > Whats the difference between a and a+ Gearboxes?? | |||||||
23rd Apr, 2007 at 09:21:42pm
As above?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
23rd Apr, 2007 at 09:44:12pm
Layshaft is different, gear tooth profile is different, idler gear shaft size is different, apart from that not a lot.
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
23rd Apr, 2007 at 09:49:17pm
i was led to belive the mainshaft is slightly smaller aswell? I've seen the future and tbh its Pie
23rd Apr, 2007 at 09:51:13pm
Could well be, that list above was just the ones off the top of my head. Vegard is the man on this kind of question.
23rd Apr, 2007 at 10:29:24pm
just bought a set of pre a+ jack knight roller drop gears. All i need now is a gearbox lol! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
23rd Apr, 2007 at 10:35:17pm
or you need an A+ idler.... "Turbo's make torque, and torque makes fun"
23rd Apr, 2007 at 10:43:29pm
24th Apr, 2007 at 12:51:50am
A+ usually have a 3 bolt C clamp bearing retainer, instead of the old A 4 bolt.
24th Apr, 2007 at 07:17:48am
On 23rd of Apr, 2007 at 10:43pm Bat said:
Hi, I think Mini Spares do a bush to convert it to the other size..... Cheers, Gavin :) Yes they do. Only 90on gearboxes approximately have got the three bolted C-clip in my book. I never had problems. The mainshaft in in the A+ gearbox is 18mm, the A is 14mm at the end. This is the end that goes into the 1st motion idler. On 13th Jul, 2012 Ben H said:
24th Apr, 2007 at 04:29:53pm
Yeah ive seen this i think its about £26??
Hi, I think Mini Spares do a bush to convert it to the other size..... Cheers, Gavin :) 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
24th Apr, 2007 at 08:31:19pm
you talking about the top bit?
