Home > Help Needed / General Tech Chat > benefits of cooling my turbo
Zeemax Power
Member #: 393
Oulton Park
i have the opion of running water through my t3 with cossie middle and i was wondering if its worth doing and whats the gain and down falls. Advice welcome
http://www.Zeemax.com
it will make you turbo more reliable in the bearing department & will keep the local oil temps down in the turbo
the down fall is........ it will place extra load on the cooling system
Zeemax Power
Member #: 393
Oulton Park
thanx for the thought
i suppose you could have a seperate cooler for it? like a charge cooler radiator, a header tank, and what-not. Could be quite an interesting project and if done properly, might even make a good difference?
Just spotted these on Ebay, is this cheap for this type of rebuild??
http://cgi.ebay.co.uk/Garrett-T3-T34-T35-T...VQQcmdZViewItem
Zeemax Power
Member #: 393
Oulton Park
i'll pipe it in for sheer lack of money but how much effect we talking waiting for someone to say good or bad
Can't be any bad side to this for the reasons above.
If by good you mean power gains, you're going to be disappointed.
What it will do is make your turbo last longer and won't cook your oil so quickly.
