Home > Help Needed / General Tech Chat > Noob Needs Help
Mad_Turbo_Uk
Member #: 1690
Hi all,
Few Questions if i may.
Im going to be running my turbo at around 8, maybe 10 psi.
I want to be taking my engine out to repaint the engine etc.
What kind of crane would i need. should i rent 1 out or buy one.
Ill have it for at least 3 weeks.
And what part of the engine to i join up to pull her out ?
It's all exciting stuff chaps *tongue*
Thanks.
t3gav
Member #: 229
Gavin@minispares.com
kent
Personally i'd buy one, prob one of the best tools in my garage and you WILL use it again, i use a folding clarke one from machine mart rated to about 2 tonnes.
yep i've got the same one, good bit of kit.
Badger
Member #: 1488
Buying a crane is always a good idea- lumping around the engines is not a fun or easy thing to do without one!
Since I'm short of funds, I'm gonna be making my own stationary one out of scaffold and a block and tackle *wink*
There is no sense crying over every mistake- you just keep on trying til you run out of cake.
Mad_Turbo_Uk
Member #: 1690
Which one would that be out of these.
Thanks. http://www.machinemart.co.uk/shop/search/f...e++crane/page/1
the cheapest one will be fine,
I have this one,
http://www.machinemart.co.uk/shop/product/...-workshop-crane
Edited by Joe C on 29th Apr, 2007.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Never had a problem with mine which is one of these,
Had pintos and Rover V8's on it, sometimes with gearbox attached and it's going strong even though it's many years old and ten different colours.
As for attaching it to the engine I normall use the studs the rockerbox bolts down to ..... never once had a problem. If your flash you could always make up brackets to mount to the water pump bolts and the stabaliser bolts like my mate has ...... but I couldn't be bothered as what is there works fine.
Mad_Turbo_Uk
Member #: 1690
That one seems good. think ill get that.
Would i need something like this
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...bayphotohosting
Or doe's it come with its own bracket.
Thankyou.
Badger
Member #: 1488
A sturdy bit of rope tied up around solid points does it as well mate. Always feel it's a bit dodgy lifting a whole lump out with those, but that's just my personal preference!
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Get a couple of m8's round is an even cheaper option :)
On 19th Jan, 2010 wil_h said:
Mad_Turbo_Uk
Member #: 1690
It will be me and my father taking it Out. :)
Right then, any tips when taking it out.
Ive taken most things of the car.
I have To take the engine mounts Off, And the One on the clutch part Looks Hard to get to..
And That part under the car that goes From where you change gear to the Gear box, Is thet easy To take off.. Some tips Would good if Ones willing To Help, or a Link or so.. Ive never Taken A mini Engine out Before, so all Little New to Me.
I dont Want to snap something
Thanks lads very helpful site :)
There is a roll pin in the gear linkaged that you will need to bash out with a punch.. IIRC the best gear to put it in for easy access is reverse!
Ive also always found taking the rad out helps a bit, as it gives a tad more room to play with side to side.
Ive always used old seat belts as slings....yeehaa! *laughing*
Neil8p
Member #: 65
South Yorkshire
Fill out your profile. If there's someone nearby they might be willing to lend a hand when it comes to the last few bits before lifting it :)
Mad_Turbo_Uk
Member #: 1690
Cool..
Should i buy a Metro Turbo Manual ? Would this help me out with how to etc :)
Thanks for your help...
Both a Mini and a Metro manual are useful investments if you are planning to build a Mini Turbo.
Mad_Turbo_Uk
Member #: 1690
It's already built.
It's a standard Turbo, Std-Gearbox.
Done about 8.000 over 7 years.
Need's a good clean, repaint etc. this is Why were taking her out. :)
Were taking her up be around 8 or 10 Psi. my father ask me to ask if there Is Any essential things we should check Or even change if were running the Higher boost while the engines out.
Great site, and thanks once again for Your support.
Mad_Turbo_Uk
Member #: 1690
Hi again.
Done some reading. and it say's you Have to change your diff if your having More boost. is that all i need to change In the gearbox? what about gaskets etc. is it easy enough job to Do. and Would the haynes Manual
(Which We have ordered) show us how To Change. just abit in the dark here.
Thankyou.
Turbo Shed
Member #: 30
Epsom, Surrey
if you tell every one your location some one may be local and pop round to give advice.
it sounds like your very new to these things and an experienced eye may spot some things you've missed
Mad_Turbo_Uk
Member #: 1690
The car will be in herne bay kent..
Just wanted to know what to order for the gearbox..
Yes I'd put the 4pin or cross pin (same thing different name) diff in while it's out.
If 10 psi is as far as you go a satndard box should last a good while, if you don't hammer it everywhere.
If you're looking to up the boost past that the you'll need straight cut g/box and drop gears as well.
Ask for the gaskets and driveshaft seals when you order the diff. Change the diff bearings too.
Haynes should tell you how to set the diff up correctly.
Richie
Member #: 628
maybe worth a center oil pickup if you are going to throw it around, but that is a big if.
if you want to run 10 psi boost, you may need to change needle in carb, and i would do a search on boost topic as you may need to work out what you can run before detonation starts, higher the boost = lower CR and deffo intercooler (roughly translated equation)
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
Mad_Turbo_Uk
Member #: 1690
I understand about the boost etc.:)
I got a 10psi needle already..
It already has a oil pickup.
Should i clean the sump out with Something too.
And It is worth getting a kad quick shift ?
And what do you mean by lower CR ?
Thankyou..
