| Home > Help Needed / General Tech Chat > Screeching Tyres | |||||||
1050 Posts Member #: 764 Post Whore Staffordshire |
2nd May, 2007 at 06:08:35pm
Just brought my estate home from the garage where its had an MOT, 2 track rod ends, the tracking and a new manifold fitted.
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
2nd May, 2007 at 06:23:45pm
take it to another garage to check the tracking again. if it is right they shouldnt charge you but check first.
2nd May, 2007 at 06:44:02pm
Edited by Bat on 2nd May, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
2nd May, 2007 at 07:12:57pm
yep, theyve probably cocked the tracking up,
3rd May, 2007 at 12:16:16am
any idea what setting i should be asking for... asying i only have the djustable tie bars and obviously the tracking... |
3rd May, 2007 at 12:27:19am
a set of BUFOONS ! have Cocked the tracking up for you
3rd May, 2007 at 07:52:46am
There is a problem here. I have never found a garage that has geometry equipment that will fit 10" wheels. The is, therefore, no way that they could have measured it.
Edited by wil_h on 3rd May, 2007. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
3rd May, 2007 at 08:46:16am
reet i'll pop into the local place in a bit... what setting should i be asking for? |
3rd May, 2007 at 08:53:31am
Yes the "string computer" works really well, and if you want a job done well do it yourself. On 7th Nov, 2008 Nic said:
3rd May, 2007 at 09:16:05am
On 3rd of May, 2007 at 08:46am Anton said:
reet i'll pop into the local place in a bit... what setting should i be asking for? I cannever remember off the top of my head. It says the toe setting in the Haynes. Slight toe-out. This is the best starting point. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
3rd May, 2007 at 09:38:22am
ok cool... i'll report back when its done!
3rd May, 2007 at 10:34:13am
1/16" toe out I think?
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
3rd May, 2007 at 11:13:33am
12 minutes or 1/16" but they probably don't understand minutes lol On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
5th May, 2007 at 08:04:35pm
On 3rd of May, 2007 at 07:52am wil_h said:
There is a problem here. I have never found a garage that has geometry equipment that will fit 10" wheels. The is, therefore, no way that they could have measured it. Don't want to be an ar*e but
On 5th Sep, 2011 Vegard said:
5th May, 2007 at 08:09:09pm
Edited by Bat on 5th May, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
