| Home > Help Needed / General Tech Chat > Help - Is this gearbox casing scrap? | |||||||
123 Posts Member #: 1234 Advanced Member Chester |
15th May, 2007 at 09:19:59pm
Doing my first gearbox rebuild and after inspection I found a crack starting to appear from one of the bolt holes in the centre web.
271 Posts Member #: 653 Advanced Member Cambs |
15th May, 2007 at 09:26:15pm
I would put that in the bin... Its only a bit of metal. If it blows it blows!
282 Posts Member #: 1404 Senior Member The Netherlands |
15th May, 2007 at 09:32:44pm
i would not use that
there is nothing wrong with a A-series that a turbo can't fix.
15th May, 2007 at 10:19:54pm
it will be ok for normal use
15th May, 2007 at 10:37:21pm
Thanks guys... looks like I'm on the search for a new gearbox.
15th May, 2007 at 10:38:40pm
Fit for scrap and nothing else, gearbox casings are easy enough to come by to make it not worth using a duff'un.
76 Posts Member #: 1038 Advanced Member |
15th May, 2007 at 10:43:16pm
Make sure when you find another case that it has the 3 bolt bearing retainer like the one you have there, the 4 bolt cases snap easily with high power. |
16th May, 2007 at 08:08:46am
Throw it in the bin. Don't use it on an original 850 either. On 13th Jul, 2012 Ben H said:
![]() 134 Posts Member #: 664 Advanced Member South Wales (chepstow) |
19th May, 2007 at 01:46:56pm
ive got the same problem can any casting be used for a metro turbo lump
![]() 725 Posts Member #: 177 Avon Park 2006 Class D Winner Woburn Sands |
20th May, 2007 at 03:54:19pm
dump it and find a 3 bold casing 16V project underway |
20th May, 2007 at 03:54:36pm
sorry 3 bolt casing, lol 16V project underway |
4th May, 2008 at 11:07:33pm
What about this one?
4th May, 2008 at 11:53:43pm
