Home > General Chat > anyone good with web hosting? cos im crap ;)
mic
Member #: 1271
ive had a play with the templates they supply but dont wanna use em so tryin to install SMF. if i give someone a shitload of passwords would anyone be willing to help a poor, starving, old tired man sort it out? or if not him, help me.
cheers
mic
www.retromods.co.uk
Doodles_Mcpooh
Member #: 1252
Cornwall
I don't mind having a go. Do you want the site built or just uploaded?
I wouldn't need passwords either way because I can just talk you though uploading it with instant messenger or over the phone.
I run my own server hosting 4 sites, but I've never heard of SMF, sorry :(
webba
Member #: 1495
Ditto bat, WTF is SMF?
Apache and IIS the only way!
What do you need? I dont know what SMF is either.
Neil8p
Member #: 65
South Yorkshire
http://www.simplemachines.org/
Was curious
webba
Member #: 1495
AHHH!, SMF, Bit like phpforum. My mates site www.consett.org.uk runs off it.
Youll need a webserver capable of running apache, php4 or 5 and mysql. (Or IIS if you can be arsed)
If your using posh web hosting, youll have to create a blank database in mysql via the host's web control panel. Youll need the sql server username and password
Edited by webba on 17th May, 2007.
If your using someone elses hosting, most of the above needs to be enabled and then a setting up period after that before you can use it.....
mic
Member #: 1271
yea its got mysql but that dont mean much to me :( was hopin to use the standard templates so didnt give it much thought.
i dont mind settin it up, id rather do that before use anyway *happy*
www.retromods.co.uk
Tazzy
Member #: 1677
Netherlands, The Hague
For a online updatable site without a database, give http://www.pivotlog.net/ a try. It's not that hard to setup & easy to customize if you know a little HTML
