| Home > Help Needed / General Tech Chat > After a bit of advice | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
17th May, 2007 at 10:53:59pm
Car started runing quiet aloud today and and smoking alotthrow exhaut and if you put your foot down it dies and won't tick over off choke and when it does tick over its loud any ideas. |
17th May, 2007 at 11:06:19pm
may, could, be terminal
18th May, 2007 at 07:28:01am
Fuelling! On 13th Jul, 2012 Ben H said:
18th May, 2007 at 06:00:14pm
try to describe the noise
18th May, 2007 at 06:14:43pm
Timing moved?
18th May, 2007 at 10:36:26pm
i was think big end or valves but didnt seem to be knocking just standard 1275 but uses oil and water and i've done the head once i was wondering maybe some else corsing the head to keep going if it is that had the head presure checked it was alright so not sure |
18th May, 2007 at 10:47:08pm
Edited by Bat on 18th May, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
18th May, 2007 at 11:02:12pm
thanks for the thoughts answer
18th May, 2007 at 11:23:30pm
21st May, 2007 at 08:40:02am
Took the head off and its blown the head gasket right through between two and three i've had it skimmed putting this down to valve sticking? was knocking a bit and smoking what do people think? |
21st May, 2007 at 08:47:40am
21st May, 2007 at 08:56:53am
cheers mate whats this a sign of if not wats next step scared its big end gone pistons are good though |
21st May, 2007 at 08:57:28am
Check the surface of the block between cylinders 2 and 3. Mine kept blowing and it was down to an uneven block face. Edited by theoneeyedlizard on 21st May, 2007. In the 13's at last!.. Just |
21st May, 2007 at 09:12:30am
21st May, 2007 at 03:49:35pm
On 21st of May, 2007 at 08:57am theoneeyedlizard said:
Check the surface of the block between cylinders 1 and 2. Mine kept blowing and it was down to an uneven block face. Mine did the same, 2 gaskets on a row, build up of carbon between the cylinders, I just went over the block lightly with chisel stone and oil to take off any high spots, not had any trouble since. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
21st May, 2007 at 08:29:39pm
found the prob i think put wd 40 on didnt seem to leak anyway i wireburshed all the carbon and two and three where its been blowing the gasket valve seats look hammered so going to have them done anyone got an idea on prize |
21st May, 2007 at 09:36:49pm
