Home > Help Needed / General Tech Chat > Ally fuel tanks.......
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Has anyone got any pictures or know of baffles in a fuel tank.
Considering making one...just don't know whats involved with the inners.
On 19th Jan, 2010 wil_h said:
I know in locost tanks thy just have a few (2 or 3 i think) ally sheets welded inside with a small triangle an inch or so cot off each corner.
are you a profesional tig welder, if the answer is no then forget about welding an alloy cell.
carl
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Yes...sheetmetal by trade fastcarl. Abit rusty at tig....but not a problem *wink*
Some tanks use an internal collector with trapdoors....
Mine has this...although not by choice.
I wanted a "sumped" style tank, which had a small reservoir at the bottom, below the main tank, which should always remain full of fuel. Obviously this would have some form of baffling at the top.
my one has a sump at the bottom that pokes out of the boot floor, the rest of it is filled with foam that will aparently do the trick
Jason G
Member #: 1459
En-suite user
Braintree, Essex
sounds good, how much does the sump hold? approx 1-2 ltrs???
mine sump is tiny
80mmx30mm
Mine's a brise one and it just has foam in it. worked ok for the mig's so its staying in mine! lol!
Jason G
Member #: 1459
En-suite user
Braintree, Essex
spoilsport iain!!!
I shall have an attempt when I got some time over winter to make one.
Build ths sump as big as it needs to be.,....
You really only need a reservoir of fuel down tere for say 30 seconds of hard fuel slosh...., so 1 litre in most cases should be more than adequate. In fact, given most Minis are carb'ed, smaller would do, as the carb itself has its own small reservoir-the float bowl.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
good tip stevie...will do some drawings and post them for people to comment on :)
Don't know if you've seen this one Fast Carl is selling?
Might give you some ideas?
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Nice one Bat....I think about 20-25 litre tank I need.
clubminiflip
Member #: 54
nr coventry
can you buy the foam for ally tanks to replace crap stuff! or is an injectable stuff?
Jason G
Member #: 1459
En-suite user
Braintree, Essex
valid point clubminiflip....is the foam anything special?
clubminiflip
Member #: 54
nr coventry
i hope its the same as what you can buy in a spray can from b&q to seal gaps around doors hehe *surprised*P hehe
i know i've heard this foam in race tanks degrades & can be replaced!!!
somat to investigate unless one of th chaps on here knows (more than likely) good bunch on here *surprised*)
Here's your tank foam...
http://www.demon-tweeks.co.uk/products/Pro...RT&pcode=AHF013
My tank also uses foam...but unless the tank is designed with suitable openeings, its not a replaceable item.
My tank was welded shut with the foam inside...
When chooisng foam, also choose a foam compatable with all fuels you might use.
ie..my foam is not suitable for use with methanol, so I couldnt really use meth in-tank...
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Good find Bat....didn't think foam would be available that easily! :)
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Jason ..... tanks ciould be a good side line for you!!!
Think about oil catch tanks and header tanks too ..... I keep looking but can't find the blend of quality and price I'm looking for ..... well I almost did but since it weighed about 1kg for a 1 litre tank I think it's a bit on the heavy side!!
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Nice idea Roger, but not enough time in the day at the moment. Could be on the cards in the future. Got to knuckle down & do my car. :)
