Home > General Chat > quicky!!! engine balancing in the south mids/warwichshire, wheres good?
clubminiflip
Member #: 54
nr coventry
engine balancing in the south mids/warwichshire, wheres good for the money? i have a full rotating assembly & rods to be done! & well i hope
As far as I know there's only one place that does it, a co. called Wilkson in Halesowen. Not 100% on that to be honest!
danwebster
Member #: 1038
WDB - Wilkinsons Dynamic Balancing, the best place to go by far.
clubminiflip
Member #: 54
nr coventry
you chaps1 big big thanks i should have my stuff ready for going to balancing by mid to the end of the week woo hoo!!! just a reminder needed too for balancing i need to take?
crank, flywheel, backplate, clutchplate, pressure plate, rods but they are done separate end to end!
i have'nt missed anything hav i?
Rods need the pistons on.
Crank damper pulley.
I was close with the name :) Lol
clubminiflip
Member #: 54
nr coventry
cool i have my pistons but have to get a damper pulley as mine is the older solid type
Yep wilkie's is the place to go, my rotating assembly all went there too.
clubminiflip
Member #: 54
nr coventry
sprocket wrote:
Personaly if it were me, id have everything balanced as individual components, crank, set of rods end to end, flywheel, pistons and pins. Then have the whole rotating assembly balanced as one as it would be installed in the engine, that includes the clutch assembly, primary gear, timing sprocket crank pulley, both bolts and lock/locating washers.
do i need bolts/locktabs etc???
i just want to take all the correct stuff so i know the rotating assembly is in good order!
for the rods to be balanced do i need the pistons on or off?
cheers all its too close to avon all this machining & building! i'll be pushing it but i'll be meticulas
