Home > Help Needed / General Tech Chat > 4 wire lambda?
pot_dan
Member #: 326
bradford, west yorks
i fitted my 4 wire lambda sensor today, but only connected the earth and signal wires, it reads nothing on the gauge, even when the engine is fully up to temperature .. i was wondering, do the heated ones NEED the heaters to work properly, or are they only really needed during the first 15 minutes or so before it warms up its self?
thanks. Dan
http://turbominis.co.uk/car/105/
pot_dan
Member #: 326
just to confirm btw the colours i used were
gray - signal
black - earth
white - heater (disconnected in my case)
thanks.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
12v feed to the heaters are necessary or the pump cell wont work.
AlexF
pot_dan
Member #: 326
thanks alex, i wired them both up to 12v with ignition and it worked!!.....for about 10 minutes and then went blank again, LOL
i had to settle for a second hand lambda sensor because i had my boss welded in and then didn't have a new one ready so had to get one quick, maybe its just because its old and doesn't work anymore..lol will try a new one.
thanks. Dan
One white wire to 12V ignition feed, the other to earth *wink*
pot_dan
Member #: 326
just any of the white wires? it doesn't matter witch one? i thought the black was the only earth and both whites were two heaters, can you get them with one white wire and they only have one heater then??? pleeaasseee clear this up! lol
thanks, Dan
If it's only got 1 wire it's got no heater and earths through the body.
A 4 wire sensor has
1 signal
2 signal earth
3 heater winding
4 heater winding
The heater winding is just that, a coil of wire, to get it hot you pass 12v through it to earth to complete the circuit *wink*
jamesfawcett
Member #: 218
Bingley, West Yorkshire
I put a 20A fuse inline with it too "just incase"
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
ALL circuits need fuses :oI
Alex
AlexF
