| Home > Help Needed / General Tech Chat > Idler Gear Bearing | |||||||
1050 Posts Member #: 764 Post Whore Staffordshire |
31st May, 2007 at 10:00:57pm
How do you get the gearbox side idler gear bearing out? Do I need a special tool? |
31st May, 2007 at 10:07:22pm
do a search mate theres a few methods all been covered before. no longer a series, but still 1.3 turbo.
31st May, 2007 at 10:07:23pm
Hammer and a drift......
1st Jun, 2007 at 12:58:12am
steady!
1st Jun, 2007 at 06:39:44am
clean well the place in oven at 200 deg for about 20 mins then it will fall out always looking for them bigger bunches of bannanas |
1st Jun, 2007 at 07:12:49am
by clean he means spotless!!!
1st Jun, 2007 at 08:57:25am
1st Jun, 2007 at 09:00:58am
hammer and punch. there not that tight. |
1st Jun, 2007 at 09:49:01am
i think hoggy is meaning the transfer case
1st Jun, 2007 at 09:52:29pm
done it... hammer and drift would not shift it... managed to find a beefy washer that was the "perfect" size to get behind it. attached a bolt and hit it... was out with a couple of taps...
2nd Jun, 2007 at 07:25:28am
sorry yes read q wrong.
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
2nd Jun, 2007 at 09:24:25am
If you plain drift this bearing out it normally scores the bore the bearing sits in, its therefore far better (if you plan on re-using the case) to heat the area with a blow torch for a few mins before removing the bearing. You'll find the bearing will literally just fall out when you are at the right temp. I've seen the future and tbh its Pie
2nd Jun, 2007 at 12:44:26pm
I sized my oven specifically .......
