| Home > Help Needed / General Tech Chat > belt drives & the types availble, 2nd hand or stick to new!? | |||||||
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
4th Jun, 2007 at 05:35:31pm
i've been mulling a belt drive over! what are the advantages/disadvantages?
4th Jun, 2007 at 06:02:50pm
4th Jun, 2007 at 07:39:35pm
have you run an engine with a belt drive before, i'm considering one for my 998 turbo build as i have no timing gear yet! i'll get somat this week!
4th Jun, 2007 at 09:48:45pm
I've been running the Minispares vernier kit for years, no problems. The belts are cheap and readily available. Much quieter than a chain.
5th Jun, 2007 at 06:38:17am
surely the belt is prone to snapping, and surley it needs changing more often say every 10000 or 20000 |
5th Jun, 2007 at 07:51:30am
5th Jun, 2007 at 08:19:09am
I' had one snap last year do to the cam and cam follwer joining holy matrimony. If I had used a chain, I have no idea on what would've happened! Broken crank? On 13th Jul, 2012 Ben H said:
5th Jun, 2007 at 11:00:13am
i'm with thisodea now! i understand the offset key thing! i was looking on the MS website, the beltdrive setup seems good, any disadvantages, mine would be going on my 998 a+ is there any problems, do i need to mod the engine plate in any way? SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
5th Jun, 2007 at 11:16:48am
The MS beltdrive goe's straight on a 998, no different to a 1275.
5th Jun, 2007 at 07:05:22pm
12th Jun, 2007 at 11:04:41pm
what parts does this consist of, i have the casing, the 2 pully wheels & belt is this it?,
12th Jun, 2007 at 11:15:36pm
22nd Jul, 2007 at 08:26:53pm
whats my timing indicator when using a belt drive, i've highlighted my mark on my crank pulley all help appreciated as always chaps
