Home > Help Needed / General Tech Chat > Pressure plate.
1380turbo
Member #: 1211
Working up the BHP ladder.
Any suggestions on which pressure plate to use on my turbo build? Spec listed below:
1380cc, Avonbar stage 4 turbo head, T3 running 16psi of boost, Phase 2 turbo cam, ultra light flywheel, lightened steel back plate.
Any ideas?
Thanks
you're going to need a grey or a double grey buddy.
What plate are you using?
Nick
Member #: 154
Midlands
i'd say definately a grey, and make sure you set it up properly so the spring sits flat by maching the backplate lugs etc. after the advice from dave it made mine and keans a lot better.
1380turbo
Member #: 1211
Not sure on the plate yet Wil_h, was looking at trying std turbo first, then a paddle plate if it slips *oh well*
bud666 can you explain in more detail please
I'd say you'll be very close, if not over the limit of a Grey. If you're lucky it'll cope, if not you'll have to go to a double Grey like i've had to do. Run the AP Rally/Race plate, you'll not need the paddle.
Phil. :)
Nick
Member #: 154
Midlands
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=7101
Star Mag
Member #: 375
Leicestershire
Thats a good link been thinking about that for a while now!
dont forget to remove 1.6 mm of the backplate 3 lugs as turbo dave advised us all some time back
gives a lot more clamping load
