| Home > Technical Chat > my theory on my problem! please read your thoughts needed :) | |||||||
8th Jun, 2007 at 10:32:35pm
back groung-
Yes i moved to the darkside |
8th Jun, 2007 at 11:44:23pm
9th Jun, 2007 at 07:59:43am
On 8th of Jun, 2007 at 10:32pm Brett said:
back groung- right my problem.... its been missing quite resently on boost (mainly coming on boost) then ok there after (getting worse over time)...but since yesterday its been missing on boost. (full stop) doesnt sound like a lean out, checked all the usual stuff like fuel pressure, fuel pressure rising on boost well as much on boost as i can get it ...it does rise so i think i am ok all here. there is no leaks (apart from a little oil but that doesnt matter atm lol) t-peice trick done variouse ways lol (dont ask), also lean of pipe blocked no difference made also for reference i know it runs on boost even if the fuel pressure does not rise but doesnt boost for long ie till the float bowl is empty (because like a twat i tried it did not let it empty tho so i still have pistons)
any way on my home from work i thought about a turbo motor needind stronger sparks to whack the a/f in to burn and thinking mine is running points atm (no module are anything) if the points have warn to a larger gap this will cause the coil to have less time to charge ( ie weaker spark, and amplified by the need for a stronger spark on boost) is my theory on this correct or fubar? your opinions needed, cheers
yes .thats true . try closing up the points,and also .you can try running the plug gaps a bit closer ,give 25 thou a try ,i run my bike at 15 thou and that works well but you really want to run the biggest gap that will still work. regards robert Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
9th Jun, 2007 at 08:26:59am
cheers guys, little more confident i havnt blown the engine :) mjlj is on its way Yes i moved to the darkside |
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
9th Jun, 2007 at 10:16:25am
the turbo dizzy was electronic so the one you have cant be for turbo. its probably the worng advance curve
9th Jun, 2007 at 10:57:18am
w00t bang on that was the problem :) points, runs better than ever set them to 0.2 mm (i think lol)
Edited by Brett on 9th Jun, 2007. Yes i moved to the darkside |
