Home > General Chat > Where can i find a Cheap ECU?
dev
Member #: 1158
Manchester
i need to find cheap ECU for my MPI preferably something i can programme as i need to be able to map it.
Any ideas?
I've looked at megasquirt but there isn't the code for A series yet, as far as i can see.
VEMS - i nearly broke my brain when working with Sprocket.
Emerald is a tad expensive
TurboDave said
"Fab's right of course.
Maybe you should take your styling ideas off the French instead! "
Unfortunately with port injection for the A series you've not got much choice!
VEMS wont do it.
MS can't yet, the code needs testing and delevoping I think?
The rest are damn expensive!
Throttle body injection is about the only option that you can bolt on and map today.
I may have an emerald ecu forsale at the end of the week, I'll keep you posted
dev
Member #: 1158
Manchester
Ok cheers Jim.
i perhaps should have said i am building a SC'd MPI so would be using a plenum mounting the injectors ala VMAX scart.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Try polestar http://www.polestarsystems.com/
Not to expensive and with the cam sensor it will do sequential injection.
http://www.twin-turbo.co.uk
Is the VMAX scart system port or throttle body injection?
dev
Member #: 1158
Manchester
Injectors are on a plenum behind the throttle body but before the supercharger.
so i would say TB injection
In that cause you can use just about anything.
I'd recommend the VEMS for the price, Sprox has already done the hard bit for you if you nick his settings *wink*
dev
Member #: 1158
Manchester
I know he's done the hard bit i sat in the car with him trying to work it all out!!
my brain isn't made for computer codes!
VEMs not all code and if anything you would do the same with MS, Talk to me about it!!
Edited by Sprocket on 14th Jun, 2007.
