Home > 998cc > engine run , but no boost , help
iamhata
Member #: 1093
hi , i install a t2 turbo, morespeed turbo head and hif 44 at my 998, finally i got my car start, but it don't have boost in my turbo , please help
thanks a lot
Dangerous
Member #: 417
You won't get boost unless you put the engine under load.
iamhata
Member #: 1093
i drive up to 5000rpm , and still have no boost ???
Is the wastegate jammed open?
Does the turbo turn freely when the engine isn't running?
Dangerous
Member #: 417
Is that on the road going along,or just reving the engine in neutral
Ben H
Member #: 184
Melton Mowbray, Pie Country
Even driving on the road at 5k with only part throttle won't see much in the way of boost on a boost gauge.
I have always found that reving the engine with all then compressor pipes off and my hand over the outlet of the compressor gives a good indication of the turbo working or not.
http://www.twin-turbo.co.uk
At idle, if you get a mirror down near the compressor intake, you should see it turning quite happily. Won't be fast - it'll be doing at least 300rpm- but it will be turning.
If it isn't turning, then turn the engine off and see if you can turn the shaft between your fingers by reaching into the compressor housing.
If it feels good, then maybe, you have a 0.63 A/R turbine - or larger??? This barely works with a 1380, so a 998 will definately struggle.
slinkey inc
Member #: 1645
Adelaide Australia.
Even on my supercharged car you can drive up to 5000rpm without seeing any boost.
Just don't put it under load, it'll be a slow trip to 5 grand but the boost guage won't show anything, I've found, in top gear at 60kph, put your foot down pretty hard, boost should come on, as it would be under load. Turbo might be different, but similiar I reckon.
Supercharged 1964 Morris 850 - Now 1330cc with 7psi.
http://www.cardomain.com/ride/2466560
iamhata
Member #: 1093
the wastegate is close , i take out my intake and saw the turbo turning , then i connect the tubro gauge,at idle my car has no vacune . around 3000 rpm i got 6-7 in.hg . when i drive up to 4500-5000 rpm , i only have 1 psi boost .
I think your gauge is no good, either that or you've got a huge hole in the inlet manifold! *wink*
You should have around 20 in.hg at idle
Is your cam timing correct?
Edited by Bat on 17th Jun, 2007.
i take it youve got the compressor housing piped up to the plenum
What did you do for the t2? did you need to flip the actuator tab around?
iamhata
Member #: 1093
my gauge is good , i remove the gage from my 05 cooper s and it work very well
Have you plumbed it in to the one way valve on the inlet? if so it wont work properly.
^^ That's a good point, where have you conncted the gauge to. Sounds silly, but you never know.
Have you got any pics showing how it is setup?
iamhata
Member #: 1093
i will post the pics on weekend , thanks
