Home > Help Needed / General Tech Chat > Something went on the RR--blue smoke from the crankcase vents
Turbo Tel
Member #: 588
Delaware, USA
Halfway through the rolling road session and blue smoke started pouring out of the crankase vents...
So whats wrong...
1.Blue smoke blowing out of the vents but NOT from the exhaust
2.Number 4 low on compression wet AND dry..
3 No 4 plug not oiled up
Please tell me this is a head/valve problem!!! not the rings...
Terry
bit weird to be honest. are the breathers clear?
i can see anything that will affect it breathing heavy other than rings.
AllanMcD
Member #: 414
Dalbeattie Scotland
Piston:(
Allan
http://www.rabdunn.co.uk/
Turbo Tel
Member #: 588
Delaware, USA
Unfortunately Piston sounds about right....
It would allow the exhaust gasses free passage to the crankcase and not cause oiling up....
S**t
I guess I'll cry a bit and then get that head off...
Edited by Turbo Tel on 20th Jun, 2007.
Nick
Member #: 154
Midlands
number 4's usually the first one to go aswell from experience.
CR#
Member #: 1367
Cape Town, South Africa
Your engine was recently rebuilt wasnt it?
Turbo Tel
Member #: 588
Delaware, USA
And very recently ripped apart as well!!
Well, got the head off and I cant see any thing on the piston or bore, no holes or signs of overheating, ditto the head... but CR is down so somethings up. Its probably the compression ring but before I get into that I'm going to get a spring compressor and take the valves out.
The RR guys theory was that the valve guide is shot which causes the valve to wobble, the seal will be bad, CR down and sends hot gasses up through the guide hence the smoke in crankcase but not in the exhaust pipe
Hey I have to be optomistic here maybe--- just maybe---he's right... but my bets on a compression ring despite the wet dry test..
I will throw you a wet fish here, as a hopefull cause of your woes.
Somehow my guides on all the valves (I forget if it was exhaust or intake) went hugely bad in a very short space of time two years ago. They had been deemed "fit for further service" at the last rebuild, but once the head was lifted the previous 'slightest movement' had shifted to around 60-thou measured at the valve head.
No idea why / how it happened, but high revs were happening prior to it 'blue smoking'.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Sounds terminal chap! I really hope otherwise though :)
On 19th Jan, 2010 wil_h said:
mikemph
Member #: 449
Oxford
If the guide were removed and pressed back in, that will be your problems as the hole (ID) is generally not concentric to the OD of the guide.
Turbo Tel
Member #: 588
Delaware, USA
Well Dave thats the same story..
The guides were deemed fit and it happened at high revs, The smoke does not shoot out like say an exhaust pipe rather it drifts out, the higher the revs the more...
I have just removed all the valves and there *may* be a defect on #4 inlet that could explain the compression loss plus its deffo looser that the rest --I would say 10 thou play Dopy me never thought to check the compression.. maybe it was always down and I rushed off to the RR anyway..
That doesn't explain the smoke though BUT No4 exhaust valve stem seal was not on the stem and fell off when I removed the springs, the others had to be persuaded off surely that cant be the cause of the smoke??
Another straw is that there just may be a semicircular mark on the #4 piston, did the valve hit it and bend? its not bad, just a mark.
I currently have the piston bores filled with ATF and No4 is not loosing any faster than the rest so far.. think I'll do the same for the head. and go fore a beer or something stronger..
I'm thinking I shoulda played Golf today!!
turboestate
Member #: 362
durham area
Hi had this problem on my way back from york at easter only number 4 down upon removal of pistons found that No4 ,3,2 had all broke there ring lands not a mark on the bores and all rings intact hope its not but sounds the same as mine .
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
Turbo Tel
Member #: 588
Delaware, USA
Holy Crap!
I just did a search on that type of failure and came up with the dreaded pre ignition.. and guess what.. it happenned when he added advance to the timing, though I must say I didn't hear anything..
Anyway Although I'm not happy with the valves and guides and I'm going to get the head done again (No4 does seem to have a very slight leak around the exhaust valve) theres no way I'm not stripping the engine to check the pistons
Just need to get the energy up..and the hoist!
Edited by Turbo Tel on 21st Jun, 2007.
keep us posted mate!
turbo hogster
Member #: 178
stowmaket suffolk
turbo estate were they the mega turbo pistons!
tel , if you read the gt17 thread in the tech section , theres a picture of my exhaust seal off a guide ,this did create spectacular smoke out of the exhaust.but none from the breathers .
could your oil be contaminated at all and burning off the contamination ? was there a LOT of smoke or a dribble ?
Mike - I've no idea what you mean here? I had given the valves a wobble test in the guides, and deciced they'd suffice for another year. I'd never remove guides only to re-fit them - I removed the VERY worn guides and the head shop fitted the newuns and serdi'd them true.
Anyways - I miss read this: I didn't see the smoke from the breathers bit, just the 'blue smoke'. Mine didn't do that - just smoke from the exhaust. Smoke from breathers is never good. Sounds like you might have ugly pistons. :(
I have had the ring lands come off pistons before - a mixture of overfuelling and too much advance in my case.
Edited by turbodave16v on 21st Jun, 2007.
turboestate
Member #: 362
durham area
No they were +40 AE hepolite turbo pistons, think it was to much advance and slightly lean mixture at part throttle 70 miles at 70MPH allthe way home was fine on the strip the steady drive home killed it!
______
/___|_____
_ (@)___(@)
is the part no on those 22357, turbo estate ??
Turbo Tel
Member #: 588
Delaware, USA
Overfuelled and advanced, Yup that sounds like the situation.
I'm rapidly coming to the broken lands conclusion as well. Thats my lesson for this project... I should have stopped him on that final run, I just cannot believe I did not stop him--My bad allowing the RR guy free head on it.
Anyway looks like I'll have time to get the engine out this weekend, I just hope Simon at Morspeed takes pity on me and gets the piston(s) out sharpish...
Edited by Turbo Tel on 3rd Jul, 2007.
yes and no, the RR guy is the expert at the end of the day. or is supposed to be.
turboestate
Member #: 362
durham area
yes that is the number on them they look like a decent quality piston to but nothing stops the dredded detonation
______
/___|_____
_ (@)___(@)
Turbo Tel
Member #: 588
Delaware, USA
Good call Turboestate!
no 1 and 4 have broken ring lands, all piston rings are absolutely fine.
the other 2 seem Ok ........... but can I trust them??
Edited by Turbo Tel on 10th Mar, 2008.
I can feel my wallet burning*frown*
I have a horrid feeling that problem could be causing the poor compression on my turbo motor.
Edited to make sense!
Edited by minimole23 on 3rd Jul, 2007.
