Home > Help Needed / General Tech Chat > a couple of questions dudes.
Richie
Member #: 628
ok where be the best place for perspex side windows ? i would like them to have the sliding hatches on for both doors ? anyone any tips re fitting them.
iam also after aluminium diamond / chequer plate on the cheap, anyone any contacts ? it is for me floor n doors.
and finally flat front style head lamps ? anyone know where i can get em ? used to have em on me mk2 and fancy them again
***I know the above should be in the wanted / general section***
ok fuel lines. i am running 8mm feed and return, i have a stock tank do i need to drill off the original outlet off the tank and have that as 8mm too or is it not that crucial ? also on fueling does it matter where the reg goes ? i was thinking about putting it in the boot so i have less pipework going to the front ?
cheers
I know there is alot there but bear with me
Richie
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
I can see what you're getting at, however, you would still need to run a boost signal to the regulator, thus saving exactly no piping!
Yuo could do with 10mm coming ouyt of the tank, as I think that's the size of the pump inlet.
I wouldn't put the reg in the boot, as you'll get fuel flow problems when accelerating.
are you coming to avon? I have some aluminium tread plate that you can have on the cheap
Its thick stuff though
try plastics4performance.co.uk for windows
Richie
Member #: 628
will need to check dates. iam advanced driving course from 30th for four weeks with weekends off so if it falls within that period i will be going :)
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Could try http://www.abbeydistribution.com/ nic.
Thats where I'll be getting my polycarbonate. They cut it for you to if required.
On 19th Jan, 2010 wil_h said:
Richie
Member #: 628
sweet, Cheers Jason.
wont be going to Avon this year, i am going to Derby with the family that weekend (big family get together)
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
www.plastics4performance.co.uk
