| Home > Help Needed / General Tech Chat > soooooooooooooooo need help | |||||||
7th Jul, 2007 at 05:38:46pm
I decided to make some changes to the indicators taking out the side repeators, that was the easy part. Now the indicators won't work. The clicker will work on bother sides, but no lights. When i unscrew the indicators from the body, the indicator comes on but does not flash. I have checked all the earths and cleaned them. I have gone over and over my tracks and cannot see what is wrong. any help would be sooooooooooooooooooooooo much appreciated. If i had hair i would be pulling it out by now. :? |
7th Jul, 2007 at 06:01:55pm
Triple check your earths. On 19th Jan, 2010 wil_h said:
7th Jul, 2007 at 08:30:17pm
7th Jul, 2007 at 08:46:34pm
i had one side working once, hence once, go know what i did. hazards well, blows the fuse. |
314 Posts Member #: 1311 Senior Member Yeovil, Somerset |
7th Jul, 2007 at 08:52:42pm
i had a similar problem with mine once, it was a dodgy connection where the lights and indicator wireing meets the main loom at the front of the engine bay.
7th Jul, 2007 at 08:57:45pm
7th Jul, 2007 at 08:58:08pm
tomorrow is a new day lol |
7th Jul, 2007 at 11:03:32pm
As bat said...check for a short. Ok until you touched the repeaters....so could be first area to start m8. On 19th Jan, 2010 wil_h said:
8th Jul, 2007 at 02:09:13pm
gone back over my tracks, got it working if i took the indicators off the front, found a short on one of the relays, now it won't work at all. Have put a new flasher unit on. anyone near b'ham who could help!!! before i start payin out for a sparky |
8th Jul, 2007 at 02:22:20pm
Check the hazard light switch, all the 4 corner indiccator circuits run via this.
8th Jul, 2007 at 02:55:08pm
do you have the engine running when testing them?
8th Jul, 2007 at 03:44:06pm
when it was working the flasher unit was working ok. i will try the hazard switch, i have not tried it cause it kept blowing the fuse |
8th Jul, 2007 at 03:51:44pm
hazard lights work. what next |
8th Jul, 2007 at 03:53:03pm
Hazard lights work? What, they work properly, all 4 flash properly etc??
8th Jul, 2007 at 05:02:01pm
yep all four flash properly wierd or what. i have sorted it now. the live on the front indicators was earth and visa versa. i have no idea why or how it happened, but it works now, everything else works aswell so two days later and it all gravy. guys thanks for all your advice and suggestions. phil |
