| Home > Help Needed / General Tech Chat > Riiiiight! :s | |||||||
11th Jul, 2007 at 01:40:12pm
Got a yellow band type pipe kit from spares this mornin, just went to fit it and this is how it all goes on:
11th Jul, 2007 at 01:50:57pm
your bias valve is in the wrong place. it should be under the pipes, but your car had the servo, with the servo cars the bias valve was moved towards the wing as the servo would have hit it. |
11th Jul, 2007 at 01:53:22pm
That is the right place if your car was fitted with a servo. The non servo placement is more to the right.
11th Jul, 2007 at 03:19:18pm
or throw away that crappy bias valve and put the top one to the front and the bottom one to the rear with a manually adjustable bias valve (can be mounted on the subframe or in the car or any place you like) |
11th Jul, 2007 at 07:28:02pm
But then you'll have no protection if you loose a front or rear line. It's good to keep them in a road car. On 7th Nov, 2008 Nic said:
11th Jul, 2007 at 11:57:05pm
Cool thanks for replies!
12th Jul, 2007 at 07:37:18am
12th Jul, 2007 at 07:40:11am
There have indeed been diagonal split Mini brake systems, my 1977 Clubman Estate was like that until I ragged all the pipes off and re-plumbed it front to rear split with a manual brake bias valve inside the car.
12th Jul, 2007 at 07:59:41am
I do not think they had diagonal split with the GMC 227 master as it has a stepped bore. That would cause havoc with different brake power at the two rear wheels... |
12th Jul, 2007 at 12:02:55pm
Cheers for the info guys, i have a front/rear split!!
