| Home > Help Needed / General Tech Chat > Quick fix before Avon!!! | |||||||
11th Jul, 2007 at 09:10:10pm
After my sesh at the rollers today found out my crank seal is leaking and it has sprayed oil all over my clutch!
11th Jul, 2007 at 09:33:28pm
Boil it in Coca Cola. This will shift the oil, makes it sticky and horrible but will work, though I won't say how long for!
6 Posts Member #: 1802 Junior Member Durham City |
11th Jul, 2007 at 09:34:51pm
go to halfords and buy the brake cleaning spray i've used it before for removing oil and nasties from all kinds of stuff and as its for brakes it dosent leave any residue behind, hope this helps grind, weld seal, grind weld seal......I love starting to grow a mini |
11th Jul, 2007 at 09:59:29pm
Although Tom's idea will work, I'd try the brake cleaner advice first in this instance. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
11th Jul, 2007 at 10:11:38pm
Brake cleaner is awesome stuff, although I'd buy it from a motor factors, should get 5L for around a tenner Team www.sheepspeed.com Racing
11th Jul, 2007 at 10:31:54pm
Depends how much the oil has soaked in, if its really soaked then brake cleaner won't shift it, you need something more aggressive, the acid in Coke works well, I've done this to rally cars with blown crank seals before, get clutch stinking hot pour a can of coke down the bellhousing, it does work!
11th Jul, 2007 at 10:36:14pm
The clutch is all apart. So would it be worth heating in some coke to shift the majority, and then clean the excess coke off with brake cleaner?
11th Jul, 2007 at 10:37:57pm
The acid gets the oil out, no sticky residue is going to help once it gets hot, you need to boil it up though, proper coke too, none of your roller cola.
11th Jul, 2007 at 10:42:11pm
Cool, will give it a go. How long do you boil it for Delia...Lol
11th Jul, 2007 at 11:29:10pm
12th Jul, 2007 at 09:41:24am
The magic ingredient in coke is Phosphoric acid.
14th Jul, 2007 at 08:29:28am
how about pepsi??? |
