Home > Help Needed / General Tech Chat > New engine smoking badly ???????????????????
ROB1N
Member #: 664
South Wales (chepstow)
Well here goes ive just run the freshly built engine from morspeed ,in consists of A turbo booster head, 1293 block omega pistons all new bearings rings etc, and a rebuilt turbo, one slight problem smokes badly ,I can understand initial start up smoke but ive run it for a while now and does not appear to be clearing but getting worse. The plugs are well oiled too.*frown*
any advice would be greatfully welcome cheers Rob
Edited by ROB1N on 15th Jul, 2007.
kav
Member #: 654
I know that freshly rebuilt engines do smoke, but this goes away over time, the oily plugs could suggest the oil seals on the turbo or valves are to blame, has there been any improvement since driving it more?
Cheers, Kav
ROB1N
Member #: 664
there has been no improvement and the turbo has had a full rebuild from its turbos the head was straight from morspeed along with the engine
Who built the engine?
Any other problems?
What's the timing and mixture set to?
Does it stop smoking if you jack the front up?
Have you tried running it with the plenum intake pipe disconnected?
How are the breathers connected up?
Take the plugs out, clean them up well. Disconnect the turbo outlet pipe leaving plenum to draw in air, and re-try. This'll confirm if it's the turbo or engine.
If it is this bad, you'll find a lot of oil inside the boost pipe.
How many miles have you done in it?
ROB1N
Member #: 664
From cold its ok but as soon as its upto temp it starts smoking,i have put it on ramps still smokes ,disconected the turbo out put pipe not a whispa of oil still smokes ?? I put the block to gearbox and head to block Morspeed built the motor i have driven for a mile or two and run for a good few hours??*frown*
is it breathing at all?
Doesnt sound good.
Mine smoked a little to start but then cleared up.
Have you had the exhaust elbow off?
Mine smoked like fook once when i had a dodgy oil drain and basically it wasnt burning any oil in the engine, just after it.
Just wondering if the dark plugs are a red herring as mine were dark due to incorrect mixture but didnt cause the smoke.
ROB1N
Member #: 664
I have removed the timing chain case with the breather for a non breathing one, to make space for the electric water pump pipes but i have got the breather on ther rocker and clutch housing.
nogin
Member #: 487
westbury, wiltshire
look down the bores, see if there is any scoring of the bores maybe
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
Running it not under load doesn't do anything really to help the rings bed in, you need to be driving it, get a couple of hundred miles under its belt and I am confident it will settle down and reduce the smoke that comes out.
Kean
Member #: 341
aka T2clubby
South Staffs
I'd go with Tom's advice here.
ROB1N
Member #: 664
I shall give it a whirl i will get back to u once ive completed some milege cheers for the advice
I really do think that is what it needs, it is also important to do mileage that varys the engine speed and load, sitting on the motorway at a steady 60mph is not really any good, stop start fast speed low speed varied is what it needs. Good luck buddy.
second that tom
it may be too late heed this guys advice
and its dam RIGHT!!!
http://www.mototuneusa.com/break_in_secrets.htm
Star Mag
Member #: 375
Leicestershire
I have rebuilt several tractor engines with the same problem if they are left to tick over by the operator Usually to keep the cab warm! they start smoking a hard session on the dyno usually breaks the glaze and sorts them out!
miniwid32
Member #: 1798
Ratingen (Germany)
Iam having similar problems myself have you fixed it now? iam now thinking that its the oil getting to thin when the engine is up to temperature?
