| Home > Help Needed / General Tech Chat > what RPM should i inject the water | |||||||
![]() 134 Posts Member #: 664 Advanced Member South Wales (chepstow) |
17th Jul, 2007 at 07:34:52pm
i have water injection and want to know roughly what rpm to inject does anybody have water injection and any tips cheers rob
450 Posts Member #: 449 Senior Member Oxford |
17th Jul, 2007 at 07:39:45pm
17th Jul, 2007 at 07:47:12pm
Rpm as the controller works of rpm ,or is it trial and error method.
17th Jul, 2007 at 07:51:55pm
dunno, my guess would be around 2500-3000RPM as thats when the boost really starts to rise, and roughly where max ign advance should be. |
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
17th Jul, 2007 at 09:16:11pm
What system are you using? Aquamist? Back once again like a renegade master |
17th Jul, 2007 at 09:32:46pm
i dont think theres many, if any, that use water injection on here. now imho that says a lot.
17th Jul, 2007 at 09:55:36pm
I know plenty of people who have used water injection on turbo minis, they have all taken it off again.
17th Jul, 2007 at 10:54:31pm
I'm not sure I agree. If you could inject it along with everything else and properly, it's not a band aid. It CAN suppress detonation etc, so if used properly it may help. It's a lot of work for little gain for sure. but if you're after the nth, why not? Digitally injected along with N2O. vrooom! On 13th Jul, 2012 Ben H said:
18th Jul, 2007 at 08:02:09am
mine worked on boost pressure |
18th Jul, 2007 at 05:52:37pm
19th Jul, 2007 at 08:31:40am
pressure switch can be got from ebay for a couple of pounds
19th Jul, 2007 at 07:14:25pm
19th Jul, 2007 at 07:36:26pm
You could run it off a MJ to inject at a set boost or a set rpm or both!
AlexF |
19th Jul, 2007 at 07:41:01pm
On 19th of Jul, 2007 at 07:36pm AlexF2003 said:
You could run it off a MJ to inject at a set boost or a set rpm or both! Alex I agree, there's multiple outputs that could be used for this. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
