Home > 998cc > CR/boost
froggy
Member #: 351
I'm building my first 998 turbo and I'd like to have some advice.
How many psi can I run with a 8,5 CR??
This engine is an old A-serie fitted with a T3 (large enough,isn't it*tongue*).
What kind of lag I'll obtain with this config??
I heard that boost will comes around 4000rpm...
Regards.
French turbocharged 998cc
With 8.5 CR you could run over 20psi I should think, I've run 18 with similar CR and a Metro T3 (I assume you have the Metro T3).
You're not far off with where the power will come in, see my graphs below.
http://www.turbominis.co.uk/_photos/random-photos/74/550.jpg
http://www.turbominis.co.uk/_photos/random-photos/74/551.jpg
froggy
Member #: 351
ok, thanks a lot for these informations.
Yes I 'll fit a Metro T3 with a MG Metro cam.
Best Regards.
Turbominis forever
froggy
Member #: 351
Best Regards.
Turbominis forever
You may be able to get it to come on boost abit quicker using Megajolt ignition.
I'm assuming Wil wasn't using it for that dyno run?
That was pre MS actually.
Don't forget the all important intercooler...*wink*
agreed with matty this is a must if you want free extra power *wink*
froggy
Member #: 351
Ok, thanks a lot guys.
In fact, I have no S/C gear box so I'd like to obtain about 100-110ch
My engine will be fitted with:
-Opel(Vauhxall) 1,7D intercooler
- Megajolt device
- Metro T3
- Maniflow 2" exhaust system
- verto blue diaphragm
- oil pump???
I think with a 8,5 CR and something like 10 psi of boost, I'll be rigth.
Is it OK?
froggy
Member #: 351
- Megajolt device
- Metro T3
- oil pump???
Is it OK?
I forgot...
I also have fitted a MG metro camshaft and a 1300 turbo head*smiley*
10psi should easily see 100bhp with that setup.
froggy
Member #: 351
Thanks a lot guys.
I'll put some pictures in a few weeks.
Regards.
