Home > Help Needed / General Tech Chat > fuel pump confusion
lil stu
Member #: 837
rugby
ive been scrolling through every previous related topic about wireing in fuel pumps,
and its just left me confussed.
Whats all this about the oil pressure switch?
i thought it just turned on a light.
cant i just put a inertia switch in after the ignition switch and run the feed to the pump from there?
would that not kill the pump, dizzy and stuff in the event of a crash?
cheers for any advice
Yes use an interia switch.
The original pump relay was connected to the oil pressure switch, but it's not the best way to do it.
Turbo Tel
Member #: 588
Delaware, USA
You should power the ignition from the inertia switch as well so that if it trips the engine cuts immediately and you dont keep driving with no pressure and get to a dangerously lean condition as the bowl empties.
Terry
Edited by Turbo Tel on 7th Aug, 2007.
Terry
But you wouldn't be able to make any boost with no fuel pressure, I guess it would run lean momentarily then die.
If you run MS there is a fuelpump output that stops the pump when the engine stops.
lil stu
Member #: 837
rugby
ok cheers guys i will just wire the inertia switch before the ignition,
and the pump after it
cheers stu
Turbo Tel
Member #: 588
Delaware, USA
Why not? its the boost pressure, fed from the plenum that pressurises the fuel in the bowl. The fuel regulator just maintains the fuel pressure 4psi above the pressure of the fuel bowl. This ensures that the fuel can get in but does not overwhelm the piddly little float valve.
Either way its not a bad thing to insure against a lean condition, there speaks a guy who just rebuilt his engine!!
Edited by Turbo Tel on 8th Aug, 2007.
Learn something new everyday.
lil stu
Member #: 837
rugby
another quicky
do i really need to buy a new carb needle, spring and needle valve
because im not sure what boost pressure im goining to be running might be anything.
cheers stu
