| Home > Help Needed / General Tech Chat > Quick SU Carb Question | |||||||
1050 Posts Member #: 764 Post Whore Staffordshire |
25th Aug, 2007 at 12:32:52pm
Does the Piston in an SU carb rise according to Vacume or air flow? (throttle position or revs?)
25th Aug, 2007 at 12:37:49pm
Airflow.
25th Aug, 2007 at 05:04:27pm
perfect.. thanks thats what i thought but wanted to be sure! thanks! |
25th Aug, 2007 at 05:48:54pm
Take it off and fit a weber you big gibbon |
25th Aug, 2007 at 07:07:50pm
Well you could argue that it rises with the vacuum (depression), the vacuum as a result of the airflow over an oriface (venturi effect), but then it all depends on what 'vacuum' the originator was talking about On 25th of Aug, 2007 at 12:37pm Axel said:
Airflow. There is a depression caused by the velocity of the air over the bridge below the piston. There are ports on the bottom of the piston that transfer this depression into the dashpot. This then raises the piston against the spring. On 26th Oct, 2004 TurboDave16v said:
25th Aug, 2007 at 08:19:52pm
Dyson??????
25th Aug, 2007 at 08:20:59pm
On 25th of Aug, 2007 at 05:48pm t2clubby said:
Take it off and fit a weber you big gibbon Is that some strange code for bugger up your part throttle economy and light load running?????? LOL ![]()
25th Aug, 2007 at 08:35:50pm
On 25th of Aug, 2007 at 12:37pm Axel said: Airflow. There is a depression caused by the velocity of the air over the bridge below the piston. There are ports on the bottom of the piston that transfer this depression into the dashpot. This then raises the piston against the spring. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
25th Aug, 2007 at 08:48:57pm
On 25th of Aug, 2007 at 08:35pm Axel said:
If you want an argument - step outside
That's fighting talk where I come from, lol Cheers, Gavin :) VEMs Authorised Installer / Re-seller. K head kits now available!
25th Aug, 2007 at 09:47:25pm
Vacuum
25th Aug, 2007 at 09:50:44pm
I can think of a supposed publication that might be able to fulfil the first two of the above statements.....?
