Home > Help Needed / General Tech Chat > Metro turbo fuel pump
chinlesswonder
Member #: 1192
In the garage......again!!
Do these pumps make a lot of noise when switched on, or are they like the standard leccy pumps where they settle down to the occassional clunk?, mine really buzzes like its struggling to pick up fuel. Recently moved it down to the boot floor to help the pick up but its still noisy.
Ps, plenty of fuel in the tank as well.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
kav
Member #: 654
Mines noisy too, I think they're just like that tbh, I rubber mounted mine to try and shut it up, might dynamat my boot out.
Cheers, Kav
chinlesswonder
Member #: 1192
Well thats good to know, glad its not foo**d. has good pressure when the engine runs at 4psi, just has a tendancy to flood the carb out, looks like another trawl around the search function :)
Probably some crud in the needle valvev in the float chamber....
chinlesswonder
Member #: 1192
looking around the search section, thats what it sounds like. May try running the engine with the pump off, then switching on, see if it washes through.
chinlesswonder
Member #: 1192
just out of curiosity, with the dashpot removed, how much fuel should be coming out of the jet with the pump running? and also, is 5psi too much pressure with just the pump running?
Edited by chinlesswonder on 27th Aug, 2007.
Dangerous
Member #: 417
Its meant to be 3.5psi,then stay at 3.5psi more than the boost you are running
chinlesswonder
Member #: 1192
is that three to five or three point five dangerous?.
Ric
Member #: 36
Basingstoke
3 point 5.
A shade more is ok, but i don't think it should be as high as 5. Oh and my pump is really noisy too, i was worried it was shagged, glad to know everyone's is the same.
Three and a half LOL!
no fuel should be coming through the jet with the dash pot off.
if it is either the pressure is too high, or the float needle is goosed.
Mine is really quiet...lol...even without sound deadening!
Mount it on one of them exhaust cotton reel rubber joblets thingys and it'll be fine.
