Home > Help Needed / General Tech Chat > turbo/supercharger?
nickthegreek
Member #: 1861
poole
ok then nutters, first time i've posted a question! when i finally get round to doing my turbo, got all the bits plus spare engine, the question is, supercharger in front of engine feeding turbo! any one done it or think it's possible??
cheers
I'm collecting bits, but the other way round - turbo into supercharger.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=125140
In my opinion, the best way to get usable boost over 30psi.
The other way round would not achieve high boost because of the positive displacement of the supercharger. The turbo, as it spooled up, would take over from the supercharger rather than add to it.
Edited by Paul S on 5th Sep, 2007.
nickthegreek
Member #: 1861
poole
thanks axel
how the hell do you plumb it in between turbo and head????/
mini23
Member #: 1296
Milford Haven Pembrokeshire
I'm also going down this route, although i've reverted back to the suck through supercharger for the summer and will continue with the turbo/supercharger route after coombe track day on the 29th.
The supercharger will be front mounted with the distributer replaced with a coil pack and the filter and alternator relocated.
Ditto.
And a clubman front to house two THS intercoolers.
Edited by Paul S on 6th Sep, 2007.
Ric
Member #: 36
Basingstoke
is someone after fentons crown? *wink*
dont meen to sound stupid..lol but what is a THS intercooler?:$
i like the idea of a intercooler as the grill on a clubman think i have seen it some where and it looks like business *happy*
Edited by Brett on 6th Sep, 2007.
Voila:
http://www.thsparts.co.uk/THSINT-001.htm
In use on Wil & Bens TT2:
Room for two and a blower?????
ahh lol i would just call it a box thing intercooler :)
mini23
Member #: 1296
Good link and not overly expensive.
I have not done anything about intercoolers at this stage and will probably get things up and running without one.
A THS cooler might fit in nicely with my install..hmm
Too risky - the air is going to be very hot after two stage compression - even with efficient compressors.
High likleyhood of detonation.
mini23
Member #: 1296
Arn't we all!
I've tried to resist going the 16v route but have not ruled it out.
I'm not sure how much power is achievable with injectors and siamesed ports.
thats a good cooler for the money, well on the face of it.
good find! :)
On 6th of Sep, 2007 at 12:14pm iain said:
good find! :)
Credit must go to Wil/Ben.
mini23
Member #: 1296
Its only to get things up and running, the coolers are a quite easy retro fit.
Controlling the rc servo driven throttle body/vent correctly is the greater concern at this stage.
Why not use something a little more robust, like a window regulator unit, or a headlamp up/down unit off a mx5 or similar?
Is this for the blower bypass?
I'm planning on using a vacuum driven actuator.
mini23
Member #: 1296
Yes its for a blower bypass.
The rc controller is a fast acting high torque unit and they control on 0-5v which I believe can be out putted from the megasquirt to image the TPS input.
