Home > Show Us Yours! > side mount intercooler..
Turbo Tel
Member #: 588
Delaware, USA
Turbo Dave was egging me on so I decided to install the IC. I earlier decided on a side mount for neatness and used a Mitsubishi IC.
Now its running I'm quite surprised at how much extra fuelling it needs on boost now, no boost change yet but I guess the cooler air is more dense so more fuel is needed. Before I was seeing >70 degrees now its in the 30's ---quite a difference though the bonnet is still off. I'm half way through polishing up a new needle from scratch so as I can keep my old (non intercooler) needle in reserve and when thats in the right area I'll try upping the boost...
Edited by Turbo Tel on 10th Mar, 2008.
very tidy
Yes!! VEry neat
Get a fan on it, and some vents in the a a panel and itll be even better
Sweet - but when was i egging you on???
Turbo Tel
Member #: 588
Delaware, USA
You told me to stop pussyfooting around!!
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=175013
So I did.... Though I dont know about 15 psi
12psi?? ----Ok OK Maybe I AM a pussy.
Terry
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Very neat install, nice to see it's made a good difference to intake temps.
As others have said make sure it's got plenty of air flow, wouldn't hurt making up a simple duct from behind the grill to feed it either.
dont think hed get a mallard in there rog...... maybe a quail ?
I think Robert has used his new lathe to for a home lobotomy. he's gone bonkers of late.
I think he saw 'duct' and got over excited.
*laughing**laughing**laughing**laughing*wil i couldnt find a tool sharp enough to get through my thick head lol
oi where else have i gone bonkers then ???*tongue**tongue**wink*
Turbo Tel
Member #: 588
Delaware, USA
I got the needle profile in the ballpark and replaced the grille and bonnet and the intake temps are a little higher, around 35 and peaked at 40 degrees during 2 quarter mile runs, still not bad on a 25 degree day especially when the thing used to run into the 70 degree limit of my sensor as soon as I hit any boost!
Intercooler alone took 0.2s off the 0-60 (7.72s) and got the 1/4 mile down below 16 (15.82@92mph)
One thing I did hit when profiling the needle was a leanoff at 3000 rpm but only when the throttle was fed in slowly.. Ok on cruise and OK on WOT ..strange.. and I could not work out which spot on the needle to work. In the end I remembered a similar problem I had at lower rpm which I fixed by advancing faster off boost and then realised that it only started when the boost came in so I added some advance on boost and it fixed it..Note to self--- leanouts can also be caused by not advancing enough..
I am now looking into the engine and wondering whether deflectors etc will make much difference, theres not a lot of places for the air to go in there!! maybe play with that another day.
Well I wasn't sure what this was about
robert said:
id get them really clean and grease free ,then cover my nipples in silicone
*happy* ah ,.... fair point !
thomenmini
Member #: 11702
Just wondering what the intercooler was off please?
Jack2eaton
Member #: 9772
Sheffield
that is a nice fit. My body is from an MPI so have cut out a big section of the side of the engine bay and replaced with a grill type mesh which has created good airflow to the rad. This would work very well on with your intercooler too.
I am also trying to find a smaller intercooler to side mount just like this and will be doing the same. Currently i have a top mounted cooler with a bulge Bonnet but i hate the look of it.
Jack2eaton
Member #: 9772
Sheffield
hazpalmer
Member #: 9038
Carlisle, Cumbria
12 years. Quite a thread resurrection. Still find turbo tels guide on polishing needles interesting
