| Home > General Chat > Help!! It wont start!! *update | |||||||
365 Posts Member #: 1211 Senior Member Working up the BHP ladder. |
8th Oct, 2007 at 09:53:00pm
Been trying to fire up this engine all day and alas it really isnt having any of it!
Edited by 1380turbo on 11th Oct, 2007. |
8th Oct, 2007 at 10:04:57pm
Sounds daft...timing isn't 180 degrees out??? On 19th Jan, 2010 wil_h said:
8th Oct, 2007 at 10:07:05pm
8th Oct, 2007 at 10:13:25pm
Swing the dizzy whilst cranking, see if that encourages it at all.
8th Oct, 2007 at 10:18:58pm
Its generally something silly you've missed. Back to basics first On 19th Jan, 2010 wil_h said:
8th Oct, 2007 at 10:19:27pm
Definately not 180 degrees out lads. No.1 is on its compression stroke. Will give that a try tommorrow Tom have adjusted the timing around but not whilst cranking. |
8th Oct, 2007 at 10:53:04pm
Its the way I always get them cracked up first time.
568 Posts Member #: 102 Post Whore Pennsylvania USA |
9th Oct, 2007 at 12:43:59am
Have you had the distributor drive out? Could be 180 deg out. |
9th Oct, 2007 at 07:08:56am
are but have you been turning engine in tedirection of travel as most peeps me included have turn engine over backwards and puts timing well out.
10th Oct, 2007 at 08:45:21am
Update time. Tried crancking whilst adjusting the timing but no joy! So i take the plugs out and they appear a lil flooded. No problem i'll spin it over and throw the juice out the plug holes. The amount coming out of 3 and 4 looked like a water ride in Florida.
10th Oct, 2007 at 10:29:54am
those pesky little choke seals !!! Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
11th Oct, 2007 at 10:56:00pm
OK a complete mystery??? Carb stripped and checked and all ok.
12th Oct, 2007 at 12:14:54am
yeah your fuel lines and setup will be fine, worked perfectly on mine for years.
12th Oct, 2007 at 07:55:34am
take off dashpot and then turn on ign and check to see if fuel comes up the main jet. if it does then float needle isnt sitting properly and flooding the engine.
12th Oct, 2007 at 08:23:23pm
OK well after 3 days of soding about with the carb, fuel regulator, distributor and checking valve timing turns out there is summin up with the new carb. All looks ok and everything checks out but its fooked!
13th Oct, 2007 at 08:37:00am
