| Home > General Chat > OT- Plumbing help! | |||||||
19th Oct, 2007 at 11:29:28pm
Got a boiler that heats both the hot water and the central heating. it heat the water and sticks in the hot water tank. The boiler is downstairs..
19th Oct, 2007 at 11:38:58pm
I've just read up that the problem could be a dodgy mixer tap, if there is a leak between them when the water is off the cold water pressure forces the hot back up to the tank!
19th Oct, 2007 at 11:52:11pm
There are two seperate systems, one is the central heating circuit, this passes water through a heating coil in the hot water tank (to heat the water in the tank, which is seperate) and then off through the radiators, and back to the boiler. This is a pumped system.
19th Oct, 2007 at 11:54:42pm
As for your mixer taps, easy way to eliminate is to go and buy a pipe slice and a load of ball service valves, then turn off mains cold water and fit one in line to each of the taps, easy to do and also potentially useful in future. Then isolate them all, and work round one at a time to see if this solves anything.
20th Oct, 2007 at 12:05:34am
yeah i have service valves in every bit i've done, not the old stuff with the house mind and its something i can do.
20th Oct, 2007 at 12:11:17am
Cold feeds are just into the header tanks yes, my system has two ballcocks, one in each tank.
20th Oct, 2007 at 08:20:28am
Edited by Bat on 20th Oct, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
20th Oct, 2007 at 09:08:53am
I have seen the same thing in my old house. I had the mixer tap shower on, but I had the cold water tap open too much. So the cold water was coming out of the shower head but also going up the hot water pipe into the cylinder and hence the header tank. It overflowed very badly.
http://www.twin-turbo.co.uk
20th Oct, 2007 at 10:07:55am
like a tap mate. to be honest i'm thinking it may be the new mixer thats been fitted in the bathroom, it uses 15mm cold feed and 22mm hot, wondering if there is a pressure mis-match, just turned the hot side off to see what happens.
20th Oct, 2007 at 10:10:18am
20th Oct, 2007 at 10:14:39am
its got one mate, but when i turned the hot off i noticed that the hot one wasnt fully open, maybe knocked as its a 22mm with a big handle on it.
20th Oct, 2007 at 12:24:46pm
well the system has been on a few houts now with that valve isolated and not water pissing out...
