| Home > Help Needed / General Tech Chat > Inlet manifold studs | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
23rd Oct, 2007 at 02:09:33pm
Are these the right lengh etc studs that go into the inlet mainifold ?
Shit Happen's |
23rd Oct, 2007 at 02:12:50pm
23rd Oct, 2007 at 02:42:07pm
No, the non threaded sextion is too long on those. In addition one end on those is UNC. Manifold bolts are UNF both ends. Edited by Vegard on 23rd Oct, 2007. On 13th Jul, 2012 Ben H said:
23rd Oct, 2007 at 03:21:01pm
Ive just found one stud. one side is of the fread is different to the other.
Edited by Markie_D on 23rd Oct, 2007. Shit Happen's |
23rd Oct, 2007 at 05:10:51pm
I assume you are after manifold to carb studs, not manifold to head studs (which I think is what Vegard has in mind)? |
23rd Oct, 2007 at 05:31:54pm
On 23rd of Oct, 2007 at 05:10pm graemec said:
I assume you are after manifold to carb studs, not manifold to head studs (which I think is what Vegard has in mind)? Yes mate, manifold to carb studs. inlet manifold studs i call it..
Why u got some spare
Cheers.. Shit Happen's |
23rd Oct, 2007 at 06:37:11pm
Don't call them that, that's something different. On 13th Jul, 2012 Ben H said:
23rd Oct, 2007 at 06:57:49pm
Don't call them that, that's something different. Ok sir
You know where i can get some ? Shit Happen's |
23rd Oct, 2007 at 07:52:47pm
As I misunderstood what you meant in the first place, my answer was wrong. If you need the studs to fit the carb to the inlet, then, the studs in the Minispares link are correct. Sorry for any confusion., On 13th Jul, 2012 Ben H said:
23rd Oct, 2007 at 07:52:50pm
As I misunderstood what you meant in the first place, my answer was wrong. If you need the studs to fit the carb to the inlet, then, the studs in the Minispares link are correct. Sorry for any confusion. On 13th Jul, 2012 Ben H said:
23rd Oct, 2007 at 09:04:47pm
On 23rd of Oct, 2007 at 07:52pm Vegard said:
As I misunderstood what you meant in the first place, my answer was wrong. If you need the studs to fit the carb to the inlet, then, the studs in the Minispares link are correct. Sorry for any confusion. No worries mate
Shit Happen's |
