| Home > Wanted > Odd. Rear brake line - From drum to braided line - that runs up the rear arm? | |||||||
Site Admin 6301 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
4th Nov, 2007 at 10:13:59pm
Mine seems to be missing on the drivers side drum - the bit that comes out of the drum, and goes up the arm/leg (whatever its called) and screws into the braided line.
4th Nov, 2007 at 10:18:18pm
If you get desperate I can make you one but it won't for a couple of weeks as I won't be able to get up to the workshop for a while. Isambard Kingdom Brunel said:
4th Nov, 2007 at 10:18:32pm
Probably got one down the w/shop. You in any rush?
4th Nov, 2007 at 10:21:37pm
only work on the car at weekends - so by next weekend would be perfect - but no, not in a real rush - want the car on the road by xmas. |
4th Nov, 2007 at 10:57:10pm
Right then, I'll get down there and have a hunt around for you. Keep on my case, a goldfish has a better memory then me! VEMs Authorised Installer / Re-seller. K head kits now available!
4th Nov, 2007 at 11:19:58pm
Thanks mate :) |
5th Nov, 2007 at 10:19:44am
Measure how long it needs to be and I'll make you one and post it with the plate for underneath the master cylinders.
5th Nov, 2007 at 10:20:00am
Drivers side, just seen.
5th Nov, 2007 at 10:28:56am
Wouldn't these sort stuff out??
5th Nov, 2007 at 10:41:38am
I dont trust myself to make a line - as brakes are fairly important..
