| Home > Show Us Yours! > 8 Port Alloy Crossflow Head | |||||||
60 Posts Member #: 629 Advanced Member Colchester |
6th Nov, 2007 at 03:13:06pm
Found this on the web, an alloy reproduction of the factory crossflow heads used on the 1968 LeMans sprite and the 69 and 70 12-hour Sebring and 24 hour Daytona Sprites (obviously would fit a Mini to). This is what (Roger Williams) the guy who reproduces these head had to say:
6th Nov, 2007 at 03:42:10pm
Looks like a nice piece of kit! Are Manifolds easy to get hold of? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
6th Nov, 2007 at 03:44:32pm
I'd say without a doubt its a case of "make your own".
6th Nov, 2007 at 03:54:40pm
Can't see it being too difficult TBH. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 902 Posts Member #: 111 Post Whore Loughborough |
6th Nov, 2007 at 04:08:09pm
very odd desgin on the inlets very diffrent from the Arden 8 port and the minisport 7 port. mite be alittle tricky to make an inlet that would fit under standard bonnet. webbers would be a tight fit. |
6th Nov, 2007 at 04:24:49pm
You historyless ignorant Mini-people. Webers will never fit without a bulge. They used Tecalemit or Lucas FI on this on Minis.
6th Nov, 2007 at 05:29:12pm
On 6th of Nov, 2007 at 04:24pm Vegard said:
You historyless ignorant Mini-people. Webers will never fit without a bulge. They used Tecalemit or Lucas FI on this on Minis. The inlets are however FAR superior to the Arden design though. trust me, Vegard is most probably 100% right on this matter, as he has an uncanny nack of nowing everything you never really needed to now about old minis |
6th Nov, 2007 at 05:38:51pm
Looks great! I bet it flows very nicely indeed!
In the 13's at last!.. Just |
6th Nov, 2007 at 05:38:54pm
What are the threaded holes for in the top of the head? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
6th Nov, 2007 at 06:23:34pm
will be due to the straighter flow into the cylinders which allow it to flow so well, with out having to go around a radius theres going to be little difference in speed
David. |
6th Nov, 2007 at 06:33:46pm
This fits:
Edited by Vegard on 6th Nov, 2007. On 13th Jul, 2012 Ben H said:
6th Nov, 2007 at 06:37:07pm
what rockers does it use?
6th Nov, 2007 at 07:46:15pm
that is one enormous ex port ,12k rpm anyone ?? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
6th Nov, 2007 at 07:55:25pm
THAT is a nice bit of kit!
6th Nov, 2007 at 08:46:47pm
Nice slide throttle, that's serious racing kit VEMs Authorised Installer / Re-seller. K head kits now available!
6th Nov, 2007 at 08:46:58pm
On 6th of Nov, 2007 at 06:33pm Vegard said:
This fits:
The Ultimate A Series Configuration. Does that engine have a slide throttle? Edited by Rob H on 7th Nov, 2007. Isambard Kingdom Brunel said:
7th Nov, 2007 at 12:40:59am
I'm sure it's the alloy block with the 4 intakes coming off it. You can see the throttle linkages going across the front of the block to the injection metering pump and the throttle block. I've think seen the same setup on a DVF Cosworth engine? VEMs Authorised Installer / Re-seller. K head kits now available!
7th Nov, 2007 at 09:53:54am
Here a pic of the chambers, I would be interested to know the standard cc, and also how much the chambers can be open up. I’m dropping Roger Williams a mail today to request some more info and pics.
7th Nov, 2007 at 10:08:18am
do you know what plugs the head takes?
7th Nov, 2007 at 08:41:03pm
wow that sure looks the part. Best 1/4 mile 13.2 seconds @116 mph
8th Nov, 2007 at 07:05:14pm
Here’s another shot of the head in situ, although I would have preferred a shot from the other side of the engine compartment. Check out those throttle bodies!
8th Nov, 2007 at 07:27:59pm
2 grand for a pair,
8th Nov, 2007 at 08:37:26pm
8th Nov, 2007 at 10:06:06pm
It indeed is! On 13th Jul, 2012 Ben H said:
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
9th Nov, 2007 at 07:04:19am
Spridget,,, so where & who do i send the money too???
www.miniman.com.au
