Home > General Chat > 131bhp mini
philc
Member #: 1346
bromsgrove
I was glancing through the current mini magazine which featured a 131bhp 1380, is this possible if so how? must have spent loads to get this surely?
Quite possible. The head and cam are the key. If you get the bugger to rev you'll see big numbers.
Hence why the K1100 headed A-series are so good, co boy can they rev.
Mine will do 125 ish. Nothing special really, 285 cam and a big valve head. It's the same as the one on the rear cover of Vizards book.
Bottom end is standard other than balancing.
The torque curve is what you really want to look at rather than the bananas ... mine pulls 66 curley whirlys at 2000 rpm *surprised*
Edited by Bat on 7th Nov, 2007.
hughesmarkie
Member #: 1197
Dublin Ireland
Yeah I agree with Gavin, its the Cam choice and head that are the key... my 1430 had 136 bananas on its last trip to the RR, Im using a Longman large port head with Rimflow valves. 36.5mm inlet and 31mm exhaust with a APT VP8C Scatter cam (which I know is lumpy) but you get power up to 8000rpm and is grand cause I dont use it as my daily driver *happy*
Yes me to i agree, very possible, Not the most pleasent to drive on the road i would guess like a turbo is, but yes well do able.
hughesmarkie
Member #: 1197
Dublin Ireland
LOL thats being nice... I know mine is an absolute pig to drive in low revs... for driveability it deffo woulnt be a preferred option *happy*
im aiming for around this in my rally car (1380), usign a 649 with 1.5 roller rockers, and a full race head 12:1 cr
philc
Member #: 1346
bromsgrove
looks like i will need to do some serious re-vamping as i have mid 80's at those wheels
yeah thats good going at the wheels though on some rolllers. i know on my rollers that equates to about 120ish at the fly.
have to say that the wheels figures is low, but once corrected, its had that many cars on there that you know the flywheel figure and its consistant for going back to etc.
end of the day the figure isnt that important, its how it performs!
philc
Member #: 1346
bromsgrove
hopefully as good as the wife *laughing*
Mine drives as sweet as. Does 30 in 4th and pulls from that. 2.95 FD*wink*
gavin-if you dont mind me asking, what size are your valves?
What sort of power could a 1275 get in this spec-anyone know?
No idea Nic, not got offset guides or anything daft like that...
ill have to start reading my yellow bible
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Didnt JohnK get 130 from his 1380 drag car? Read in a mag somewhere.
Alex1340
Member #: 111
Loughborough
My aim is to get 138bhp from my 1380cc. Im at about 120bhp before i changed to 1.5 roller rockers and twin carbs (if they will help) need to find 18bhp from some were mite take the alternator off for the rolling road. hehehe cheating i know.
fortfun
Member #: 954
Fort Collins Colorado USA
Surely you can rig a heavy duty relay to disconnect the alternator electrically, which will make it take practically zero power. Then you could switch it off whenever you needed the extra.
However, I don't think you'll see much benefit. When putting out 50 Amps, that is 700 Watts at 14 Volts. That is a bit less than one horsepower output power. Wikipedia says the conversion is at least 50% efficient. So that says at most you could gain 2HP - probably less.
Fantastic to think of getting 100HP per liter from an A-series with a 5-port head! What sort of RPM?
1275 with Back Door Turbo
Alex1340
Member #: 111
Loughborough
last run peak power was around the 6k mark, with the rockers it mite be higher, of course the problem with rolling roads is on one you mite get 120bhp on another only 100bhp or more or less there abit pants like that but a printout with 138bhp would be nice.
I dont think the 130bhp 1380 and being drivable is a problem to achive at all.
Im looking at my 1400 and thinking that with 100 bhp/lbft on a 246/276 cam, standard MG metro valve sizes and standard bore LCB, that extra 30 isnt that far away?? with a 286 scatter cam, big valve head and a large bore lcb. Add to that the benefits of fully mapable ignition and fueling.
I dont see it being a problem and driveble.
Compression ratio is the key that brings it all together.
Not only is that kind of power possible from a 1380 but there's one producing even more power in the for sale section.
put a T2 on there and run it at 8psi intercooled
BIG torque figures and a shed loads of horse power
not many RPM either
johnK
Member #: 690
Norfolk
the last time my 1380 5 port was on baldwins rollers showed 146bhp - real 130bhp ish, and was quick and streetable, the 1380 K on the other hand is in another leauge entirely and has a far broader span of power
JK
If Carling made Mini engines
