Home > Help Needed / General Tech Chat > (dont know where to post this) Turbo to fit mirage
mike998
Member #: 2069
Oxfordshire
Just out of interest are there other turbos besides the T2 that will fit the Mirage manifold without any bulkhead mods?
If so what are the different affects the other turbos will give ie. spools up quicker, Gives more boost.
cheers
a hybrid of a t2 will do what you want
There's the T25, but could weel be too big for a 998. There may be some of the GT series with a T2 flange you could use as well?
Turbo Tel
Member #: 588
Delaware, USA
Theres a GT15 with a T2 flange, Mine works so well on my 1298 that it keeps blowing the pistons!!
mike998
Member #: 2069
Oxfordshire
im not building it to a 998, its going on a 1275.
my user name is mike998 because thats my user name on other forums and its easier to remember.
Turbo Tel
Member #: 588
Delaware, USA
Well I think that if you want a nice road car then a GT15 is the perfect match, it is efficient, spools up well and works great. I recon I get just as much power out at a given psi than most others but it comes in real low, However, eventually (12psi??) it will run out of puff so if you are after a dragstrip car then you will need something bigger.
I have not seen anyone try this on a Mirage manifold but it should fit..
The problem is getting hold of the T2 flanged version, I bought mine new ($500- a steal at the current exchange rate!) and its called a 1548, but I have not found a car that its actually used on yet...
Where did you get that from Tel? You got a linky or something, please?
Turbo Tel
Member #: 588
Delaware, USA
Just looked it up and the price has taken a hike.. its $650 now not such a good deal... I even checked my receipt thinking I must be talking out of my A$$ but no, $495.. in early 2006
http://www.atpturbo.com/Merchant2/merchant...gory_Code=GTNBB
I reckon that the Gt17 will fit on the mirage manifold.
This is a picture of a T2 and a GT17 turbine housing:
The T2 is on the right. Cant confirm that you would not have to grind the block or the compressor housing though.
The GT17 is fitted to a lot of Saabs. Do a search for "GT17".
I'm looking for a direct replacement to the T2.
I only need 10psi, so the GT15 would seem to fit the bill, but I can't find a cheap one of those either :(
