Home > General Chat > Beam Axles
Alex1340
Member #: 111
Loughborough
Are these Beam axles which uses std mini radius but with a pair of coilover shock any good? Seen afew people using them, i currenty have the standard subframe and high lows with camber adjustment brackets and fully adjustable shocks worth changing over to coil overs?? whats the feeling on them?
Thanks
Alex.
What you have will be very good. There will be no noticeable difference in handling but you will lose around 25kg of weight.
If its weight saving you want, do it, if not, dont bother.
I have an alloy beam that I made myself with KAD alloy trailing arms and it is very good.
Paul
JT
Member #: 637
Hertfordshire
can you keep the handling good?
iv heard that rear beams make the handling a bit strange. or is it down to prefernces?
cheers
josh
My build thread..
cheers
josh
It depends whether you have it set up properly. My handling is great even with parallel rear tracking angle (for drag strip).
Paul
hughesmarkie
Member #: 1197
Dublin Ireland
I agree with Paul, its all about how you set them up! Ive got em on both my minis and they can be very versatile and supper easy to adjust, spring weights for your application are important.
On my clubby you can adjust the height really easily by having some large threaded pipe welded in to strengthen the rear shock locations, just means more adjustment to get the set up I want*happy*
I think I have a pic ill post it if you want to have a look*happy*
JT
Member #: 637
Hertfordshire
yer a pic of that would be good mate.
im now tempted to get one fitted to my project!!
does anyone know the wieght of a minispares beam? as i think thats the one to go for.
cheers
josh
My build thread..
hughesmarkie
Member #: 1197
Dublin Ireland
Here you are Josh, as requested
And heres one a bit further out so you get a bit of scale!
The blue socket sits into the top pipe and allows it to be adgusted using the power bar *happy*
regards, Mark
nice idea mark, never seen that before
Si P
Member #: 912
North Yorkshire
josh_tacon - here's a pic of my alloy minispares rear beam.
weight = 10-12kgs at a guess.
They are a right bastard to fit mind you. i had to mod it quite a bit to make it fit, Also,you have to use a mk1 handbrake cable set-up or like i've done have cable made up.
They don't tell you that when you buy one. If i was to do it again i would make own.
Si
Tazzy
Member #: 1677
Netherlands, The Hague
Looks ff-ing awesome though
Si
No you dont, a couple of friends have fitted them with late handbrake assy and cables.
Paul
Edited by paul wiginton on 11th Nov, 2007.
Si P
Member #: 912
North Yorkshire
Paul- How did they manage that? I have a late type handbrake set-up on mine.
And when fitting the rear handbrake to the single front cable which goes to the handbrake. There was no way it would reach.
I used KAD quadrants on both the radius arms and on the beam itself,(see pic ) And there was just not enough cable for the two to meet.
I think I've got some pics which I will post. May be you can see were it all went wrong?
Si
Si, to be honest I dont know, I havent looked, but I will find out and let you know.
Paul
Si P
Member #: 912
North Yorkshire
Thanks Paul any info would be good.
Si
The quadrant on the radius arm is bigger than the cable guide on the subframe.
Maybe you could remove the guide off the subframe and bolt it to the beam?
Si P
Member #: 912
North Yorkshire
Bat - i actually thought about making up some reduced size quadrants to gain the length back. Might give it a go. *indifferent*
could you not make up a threaded extender to screw onto the cable?
