Home > Help Needed / General Tech Chat > Running in oil
kav
Member #: 654
Hi, I have just done 50 miles on my new engine with mineral oil, I've just done an oil change, but this time I've used a semi-synthetic, is this a very bad idea? should I still be using mineral? Is it even worth draining and using mineral?
Thanks in advance,
Kav
50 miles is no where near long enough to run the engine in. I'd go to 1000 miles before putting any thing synthetic in.
The engine needs to wear to get the rings bedded in. Just my opinion...
kav
Member #: 654
yeah i havent finished running in yet, still running in was gonna go 500 miles, is sythetic really no good then?
Take a good read of this......
http://www.mototuneusa.com/break_in_secrets.htm
Oil is mentioned a good way down....
KAV, please have a look at this website and read all to the end
this is also born out of my experience well ......................................http://www.mototuneusa.com/break_in_secrets.htm
Jason G
Member #: 1459
En-suite user
Braintree, Essex
ELB's in Suffolk who did my crank also said the same thing. A very fine hone. Build the engine with the oil you intend to use is the only different thing I've heard.
Once you've oil pressure, Keep the revs up & don't let it idle. :)
Edited by Jason G on 12th Nov, 2007.
