Home > General Chat > Acronyms
[helpful] I remember a French guy asking about an acronym on here a few weeks ago, could we have a sticky in beginners tech with them all listed for new/foreign peeps? [/helpful]
Lets see how many you can come up with*wink*
Starter for 100
EGT
WBO2
TPS
CLT
IAT
MAT
MAP
MAF
AFR
PSI
KPA
MM
SU
BP
AR
CR
FD
CO
HC
Nick
Member #: 154
Midlands
how about the most famous one?
BAC
EGT - Exhaust Gas Temperature
WBO2 - Wide Band Oxygen Sensor / Gauge
TPS - Throttle Position Sensor
CLT -
IAT -
MAT - Manifold Air Temperature
MAP - Manifold Air Pressure or the Matrix within and ECU
MAF - No idea what it stands for but it's to do with air flow
AFR - Air Fuel Ratio
PSI - Pounds Per Square Inch
KPA -
MM - Millimetre
SU - Skinner Union (carb company)
BP -
AR - Again can't remember what it stands for but in a nut shell the size of the turbo
CR - Compression Ratio
FD - Final Drive
CO -
HC -
WTO - Wide Open Throttle
TBASE - Tuning BL's A Series Engine (aka the Yellow Book)
MSA - Motor Sport Association
BAC - Bloke's A Cabbage
[EDIT] I got MAP slightly wrong see Gav's response below for the correct definition [/EDIT]
Edited by Rob H on 10th Dec, 2007.
CLT - Coolant Temperature Sensor
IAT - Intake Air Temperature Sensor
KPA - Kilo Pascals (Pressure)
MAF - Mass Air Flow Sensor
MAP - Manifold Absolute Pressure
BP - Back Pressure?
AR - Area / Radius????
CO - Carbon Monoxide
HC - Hyrdo Carbons
Here's my additions ...
NoX - Oxides of Nitrogen
IMO - In my opinion
IMHO - In My Humble Opinion
IIRC - If I Remeber Correctly
EGBP - Exhaust Gas Back Pressure
BP: British Petroleum
CR#
Member #: 1367
Cape Town, South Africa
thoughtt it was "Beyond Petroleum"?
oh well.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
watch out Veg. They are only called BP these days, and may well sue you *wink*
Check this site.
http://acronyms.thefreedictionary.com/
LSA - Lobe Separation Angle.
LCA - Lobe Centreline Angle.
Sam
Member #: 1686
Oxford
thought bac ment something else... something abit rude, but also here is another bac
BAC- Bypass Air Control isent that the valve that stops pre ignition by utterly leaning out the fuel ratio? or am i being a twit?
OMG Robert that's a big one
Yes it does mean something a bit ruder, Rob's being polite *wink*
Bypass Air control - Controls idle speed as it varies the amount of air bypassing the throttle plate.
bobfoc
Jay#2
Member #: 648
Northern Ireland (ex AUS)
ANNUS
On 7th Nov, 2008 Nic said:
naeJ
m
t3gav
Member #: 229
Gavin@minispares.com
kent
Yep AR is area/radius your forgetting lol- laugh out loud and pmsl piss myself laughing :)
ROFLAO - Rolling Around on the Floor Laughing My Ass Off *wink*
On 11th of Dec, 2007 at 12:19am joeybaby83 said:
bobfoc
She works in my office.
Jay#2
Member #: 648
On 11th of Dec, 2007 at 07:53am Jay#2 said:
ANNUS
Another
Newbie
Not
Understanding
Stuff
naeJ
m
