| Home > Help Needed / General Tech Chat > Drive seals | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
10th Dec, 2007 at 12:25:47pm
10th Dec, 2007 at 12:51:25pm
Drive shaft seals can be changed with the engine in the car after removing the drive shafts.
10th Dec, 2007 at 03:55:57pm
can the the FD gears be changed with out splitting the gear box from then engine? I know the diff will come out but can you get to the other gear easy enough though the diff hole? |
10th Dec, 2007 at 05:16:30pm
On 10th of Dec, 2007 at 03:55pm Alex1340 said:
can the the FD gears be changed with out splitting the gear box from then engine? I know the diff will come out but can you get to the other gear easy enough though the diff hole? I wouldnt have thought so, the speedo drive would have to come off, the gearbox would have to be locked up to remove the nut and that has tabs as well. Even then I cant see how you could swing a big enough wrench... Thats an engine out job if you want to do it right. Having said that some pervert will have managed it!! Edited by Turbo Tel on 10th Dec, 2007. website:- http://www.terryhunt.co.uk
10th Dec, 2007 at 08:20:36pm
I once watched, and I have to admit laughed an awful lot....as a friend removed a Mini engine from his car, in the snow, with no lifting gear.
10th Dec, 2007 at 09:55:07pm
But to change the FD you can do it with the engine on the box right?
10th Dec, 2007 at 10:06:05pm
10th Dec, 2007 at 10:14:49pm
not just lob it in first and lock the flywheel as per undoing the flywheel bolt?
10th Dec, 2007 at 10:26:19pm
11th Dec, 2007 at 11:04:32am
personally i'd always use 4th as then there is no load on the gears, only the main shaft, and drops.
On 10th of Dec, 2007 at 10:14pm iain said:
not just lob it in first and lock the flywheel as per undoing the flywheel bolt? yeah the pinion is the only bit thats got me thinking, surely it must be do-able? On 28th Aug, 2011 Kean said:
