Home > Help Needed / General Tech Chat > ID this Panel
webba
Member #: 1495
Whats the posh name for this panel? inside door, goes behind inner wing? Thin long rectangular panel with a hole near the top. One of mine needs replaced, not sure on name.
A Post? Inner A Post maybe?
Turbo Tel
Member #: 588
Delaware, USA
A post boxing plate??
Inner A post?
Item 18?
http://www.minimania.com/web/CatPage/12-7/...per_Catalog.cfm
Or
http://www.minispares.com/SearchResults.as...mple&ty=fi&rt=1
Edited by Turbo Tel on 11th Dec, 2007.
not sure there is a repair panel for this - I always made my own
Rob
Tel's got the name, I've got the info *wink*
http://www.bmh-ltd.com/p63v.htm
Part V8
I'm sure I saw v8 and v9 as one earlier this year in a mini parts place. it was the whole pillar section and door hinge mount. an old bmc part it was. I can look into it if you fancy cutting the lot out.
They're only a tenner each, so I'd say it's the one :)
if i'd known I could buy one....doh......
slater
Member #: 1291
Suffolk / Birmingham
i call it 'bit of 1mm sheet with a bend in'
webba
Member #: 1495
thanks for info!, im visiting mmachine next week (5mile from work) so will see if they have em
webba
Member #: 1495
£6.50 at m machin, sorted!
