| Home > Help Needed / General Tech Chat > Crank Thrust Bearing material | |||||||
18th Dec, 2007 at 05:30:49pm
I'm going to make some oversized thrust bearings so that I can fit an 850 crank in a 998 block.
Edited by Paul S on 18th Dec, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
174 Posts Member #: 781 Advanced Member Norway |
19th Dec, 2007 at 10:55:21pm
i think standard bearings is maed whit a copper lead something. Look on youtube. Found it there erlyer today.
20th Dec, 2007 at 12:14:05am
20th Dec, 2007 at 07:57:32am
I think that they're steel backed phospher bronze.
20th Dec, 2007 at 08:50:06am
I've pulled a thrust bearing out of one of the engines and it is steel backed and looks like bronze type bearing surface.
Edited by Paul S on 20th Dec, 2007. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Dec, 2007 at 09:05:22am
Why are they steel backed? Is it becasue of some thickness or heat considerations, or cost of the material? On 13th Jul, 2012 Ben H said:
20th Dec, 2007 at 09:15:27am
I would guess at cost, the bronze is only about 0.5mm thick.
20th Dec, 2007 at 09:33:17am
Edit, scrap that, it wouldn't work
Edited by wil_h on 20th Dec, 2007. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
20th Dec, 2007 at 10:48:23am
20th Dec, 2007 at 10:57:38am
No not really, as there is no metal to metal contact. Remember the oil-film. On 13th Jul, 2012 Ben H said:
20th Dec, 2007 at 10:58:48am
I'm hoping that making them twice as thick will make them stronger.
20th Dec, 2007 at 11:01:27am
We still use the dowell method. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
20th Dec, 2007 at 11:02:44am
On 20th of Dec, 2007 at 11:01am wil_h said:
We still use the dowell method. Excellent! Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Dec, 2007 at 11:14:50am
isn't phosper bronse sort of brittle?
20th Dec, 2007 at 11:19:35am
On 20th of Dec, 2007 at 11:14am mini13 said:
isn't phosper bronse sort of brittle? i'd be worryng about it breaking up, especially with mini thrust pressures... How about using 2 lots of thrusts, one as a bearing and one as a spacer and actually screwing them to the block, could the screws be located in the 2 "grooves"? Phosphor Bronze is brittle, but it should not see any significant loads. As Vegard pointed out, the oil film should prevent any actual contact with the crank. The problem with using two sets of standard thrusts is getting them to the exact thickness. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Dec, 2007 at 11:27:56am
You could make two work, but you'll need to surface grind them. When I pulled the turbo engine last time, the thrusts had worn 2 thou, but the outer edges of the thrusts had never been in contact with anything. Thrusts from the factory are very rough. I like to surface grind both sides of new thrusts. On 13th Jul, 2012 Ben H said:
20th Dec, 2007 at 12:23:38pm
surly despite there being an oil film the thrusts will still see a load, after all it has to go somwhere.
20th Dec, 2007 at 12:34:12pm
On 20th of Dec, 2007 at 12:23pm mini13 said:
surly despite there being an oil film the thrusts will still see a load, after all it has to go somwhere. Yes it has got to support the oil film. But I think the load would be more compressive than rotational, so as long as the thrusts are adequately located, then should be OK. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th Dec, 2007 at 01:04:13pm
Ah,
