Home > Help Needed / General Tech Chat > rear shocks
Markie_D
Member #: 1660
Formally Mini_Uk
London
Quick Question
Im just doing the rear shocks.
What torque should the top bolt be. or does it have to be so tight, as to make the rubbers compress just a little or alot. ?
Have a nice christmas.
Cheers lads..
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
Guess know one knows :$
<-------Will them tits persuade you *wink*
Edited by Markie_D on 25th Dec, 2007.
Shit Happen's
yes they have .....lol
tighten till the rubber compresses around a third then use the lock nut double nut and lock the two togeather
these should be supplied with the shocks
Excuse my English, but what does this mean?
Markie_D
Member #: 1660
Formally Mini_Uk
London
Means, know body knows how to do the job *wink* ..
If you wanted writen like this, so you might understand.
Guess no one knows lol
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
Only lock tight nut's come with the shocks steve.*surprised*
Got them from minispares. GAZ Shocks
Can't get more then 1 nut on there mate.
But ill do that :)
Cheers steve.
Merry christmas mate..
Shit Happen's
As you are compressing a rubber bush when you tighten up the nuts I would question if it is actually possible to torque them to a precise value and even if you did would they remain torqued up over time.
In my opinion your best bet it to do them up tight.
Note that is purely my opinion, I'm sure someone will correct me if I'm wrong.
Edited by Rob H on 25th Dec, 2007.
When I fitted my Gaz shocks I tightened them up as far as they'd go, which wasn't far.
Then I had to re-tighten them after a couple of weeks driving.
Easy to do on an estate though *wink*
Markie_D
Member #: 1660
Formally Mini_Uk
London
When i tighten them up as tight as they can go.
The rubber compresses quite alot, where the rubber become's really flat. so like rob said, there should be a torque setting really.
Just seems unsafe to me, that it should be done up so it's only compressed so much. then it will become losser.
but tighting them up tight, which makes the rubbers flat. i would of thought that wasn't a good idea, as then the rubbers are not really doing there job..
They should of made the top part where the nut goes on longer,
So you can place another nut on.
Shit Happen's
When I said as far as they would go, I should have mentioned without squashing the bushes flat! :$
Just wind them on till the thread just sticks out the top, then run for 2 weeks and tighten them down a bit more.
Once the nyloc bites on the thread, they won't come loose, just keep your ear out for knocking noises as the bushes bed in :)
Edited by Bat on 26th Dec, 2007.
Markie_D
Member #: 1660
Formally Mini_Uk
London
*tongue* Ill do that Mr Bat *wink*.
Once again, Cheers for your help lads.
Be lost with out that help *happy*
Shit Happen's
Oh. No one. Please write that then :)
Also thinking about the loading on the shocks I would question if the top nut does anything other than stopping the shock falling off when the car is jacked up.
What do you guys reckon?
Edited by Rob H on 26th Dec, 2007.
As long as it's tight enough to keep the bushes compressed a little, so there's no slop when the shock bounces up and down.
Job done :)
Markie_D
Member #: 1660
Formally Mini_Uk
London
<------ bet she be good at the *wink* lol
Shit Happen's
I think there is some element of pull on the thread as shocks have a rebound damping action.
