Home > General Chat > Minispares SC gear ratios
RED850
Member #: 89
Sydney Australia
Hi all,
Just a quick question, has anyone played with the ratios available in the minispares SC gear sets and found the best suited for a turbo mini.
in my thinking yes you want close ratios but at the same time you would want taller than std gears to load up the turbo to make it work and spool up with less load on the engine the turbo is not going to work as hard if you know what i mean.
I have tried 2 boxes the 3 syncro MK1 S box (which i just screwed 2nd gear in) and a 4 syncro MK11 box both fitted with 3.4 diff.
I was thinking of just changing to a 3.2 diff as this would lessen the wheel spin in 1st and 2nd gear and get me off the line quicker too.
tell me your thoughts people as i am about to outlay the money to buy SC kit from minispares and Quaife ATB from swiftune
Grant
179hp on 12psi 1293cc of pure A series
14.0et @101 mph
I can see what your thinking, But I don't think it's the case.
For example take mine, with a 2.9 diff and the MS gearbox, I get around 50 mph in first, now the lag in first gear is very bad and it don't start hitting boost until around 30 odd mph! Now if i had a lower gear ratio i would be hitting boost sooner and would spend so much time being over taken! lol.
double post sorry only pressed once.
I can see what you are thinking, but the load is only really a problem in first (and maybe second) gear. The MS kit has taller first and second ratios than the standard box, so this coupled with a slightly taller diff should be the answer.
In reality theslightly less torque developed in first because of the reduced load is a good thing, as wheelspin in this gear isn't a problem anyway. Even with 7" slicks I never manage to get the throttle fully open on my car in first.
The MS kit makes a massive differance through the gears and is worth every penny.
Don't know if you've seen this from the MS site?
4-SYNCRO 2.58 1.71 1.25 1.00 - CLUBMAN gear set. Ratios almost
identical to above as this was conceived
as a useful s/cut kit for the road, so same
applications - but without 1st gear probs.
2.54 1.73 1.22 1.00 - ST gear set. Taller 1st gear and slightly
closer ratios make it better suited to
circuit racing, rallying, and the bigger
capacity engines - ie. 1380cc plus.
2.31 1.57 1.19 1.00 - METRO CHALLENGE gears set.
Very tall 1st gear originally designed for
rolling starts, so less than ideal for static
starts. Low FD needed if used for sprints
or hill climbs, especially if 13” wheels
are being used.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
This post might also be useful for reference. I'm still not sure what way to go myself.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=159190
Edit, and this:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=126550
Edited by Jay#2 on 4th Jan, 2008.
On 7th Nov, 2008 Nic said:
naeJ
m
There is a little good information here:
http://www.minifinity.com/index.php?name=P...0996&highlight=
Just try to block out the 'bad' information however... LOL
Ive just bought a 1275gt box, jack knight sc drops and im seriously weighing up the idea of having them cryo treated!!
Jay#2
Member #: 648
I'm not a member of Minifinity but every time a read a thread on it it never ceases to amaze me! There's always someone spreading mis-information like a disease.
naeJ
m
i will go with wil_h thoughts 100%
Star Mag
Member #: 375
Leicestershire
Me three i am using the ms gearset with a 3.1 diff and have to say it is superb alot better than my standard turbo box and diff!
I forgot how funny that topic is along with the one linked to in said topic*laughing**laughing*
Yes, a 2.9 with the MS gear kit is just a little to tall IMO.
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Ha ha. Dave that post on mf is top class mate. As well as the tom and alex helping out and wolfie being awquard. (sp?)
Edited by Jordan on 4th Jan, 2008.
RED850
Member #: 89
Sydney Australia
thanks guys i appreciate your thoughts, I am currently using a 4 syncro remote box with 3.44 but i am not sure if the clubman gear set suites remote boxes, I have sent an email to Mini Spares and will see what they say.
but if they do fit i will order a 3.2 diff and clubman gearset and look forward to seeing the changes.
Grant
14.0et @101 mph
Red.
I dont think the Evolution kit can be put into a remote box as you would need to use your existing reverse gear due to it being machined differently for the remote selector,. I think you'd need you reverse as A and A+ 1st is a different ratio 3.2 vs 3.6??
I am using this kit which is the same as miniwilliams uses albeit the remote version
http://www.minispares.com/Product.aspx?pid=38071
